I was wondering what year golf and jetta steering knuckles fit our cars?I have a bad bearing on the right front,but have a chance to get a knuckle from a wrecked 2001 GTI..(hit in the rear)engine and trans are already out of the car,but they left the suspension intact.Thanks!!....p.s. I already did a search on the web,and here with no results....keep on buggin...
I'm assuming yours is a 2.0?
TDI's and 2.0 have 280mm brakes. 1.8T's (like that 2001 GTI) and VR6 cars have 288mm brakes. So for a direct bolt-on with no other mods, you would be looking for any A4 chassis (98-current NB, or any MK4 Jetta/Golf) with a TDI or 2.0 engine. Now if you grab the calipers, carriers and knuckles from both sides off that GTI, and get new pads/rotors (order for the same car) then you can have the upgraded brakes on your car. If the pads/rotors that are on there look good, just run them until they wear out.
![]() The A4, aka mk4, Chassis Jetta was 1999.5-2005 and the mk4 Golf was 1999.5-2006.
| steering question | modernage | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 03-02-2008 05:23 PM |
| Help! Steering knock!!! | archiebug | Questions, Issues, Concerns, or Problems with the New Beetle | 5 | 11-26-2006 07:56 AM |
| A4 Steering wheel question??? | mezonesxbox | Styling Modifications | 2 | 11-06-2006 08:25 PM |
| p 0411 code question and coolant leak question.... | bobbittle | 1.8 Liter Turbo | 5 | 06-12-2006 02:47 PM |
| Help With Power Steering | mezonesxbox | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 05-08-2006 08:35 PM |
