ok i have searched but not really found what i need help with.
i have a 2000 2.0 beetle.... i want to lower my car. i love the slammed look but know its not always practical. so i dont want coilovers, i want springs. i hear that if i go lower than 1.5" i need to change the swaybar? i can get h&r springs for about $150 at a local shop. i had that brand on my passat and loved the ride. now i also see that ecs tuning.com has some RSD springs that loWer the car about 55mm front and rear FOR ABOUT $180.do i need the swaybar? thanks for the help |
Lowering springs don't go that low, so forget even getting close to slammed and they aren't adjustable so whatever height they are at that's where they stay. Plus the stock struts aren't meant to be compressed to the level they'd be with lower springs so you'll blow your struts eventually too. If money is tight, i'd say go rokkor coilovers. I have them and no real complaints. They are now way B&Gs or anything, they are a budget coilover kit. But that's ok if you understand the implications: really low=less ride comfort and possibly lacking in durability and handling capabilities.
My 2.0: 'Lil Red' |
Rokkor no longer makes mk4 coilovers ![]()
wwwaaahhhh!??
damn..got mine just in the nick of time, then! ![]() in that case, these are your next best bets: Volkswagen New Beetle 2.0 > Suspension > Coil Overs > ES#1905686 MK4 JOM BlueLine Coilover Kit - 741001 or Volkswagen New Beetle 2.0 > Suspension > Coil Overs > ES#250775 Street-Line Mk4 Coil Over Kit - SMVW8005KT EDIT: they seem to still have them, FL http://www.rokkortuning.com/p-29-rok...k4-beetle.aspx |
W00t!! I know which ones I'm getting ![]() ![]() |
Don't run without a swaybar unless you are completely slammed, and I mean tucking at least 1" of tire.
I run no front sway on my 2.0T but it definitely affects the handling. I'd suggest getting an aftermarket front sway if you want to keep your handling predictable. Bump steer is a pain and you can feel the car corner dive when you turn and if you're low this causes rubbing on the fender liners. The only reason I got rid of my FSB was my car is too low even for the aftermarket one I had in it. |
You will have problems rubbing the swaybar if you go much under a 1" wheel gap in the front. If you have aftermarket axles you will be able to go a little lower without rubbing.
| Almost out of warranty! Please advise... | Severe | Questions, Issues, Concerns, or Problems with the New Beetle | 1 | 08-24-2009 11:26 PM |
| re:transmission advise | mbz03 | Transmission Talk | 0 | 08-08-2009 10:35 PM |
| Please Advise!!!! | armyssg401 | Questions, Issues, Concerns, or Problems with the New Beetle | 4 | 05-05-2009 12:07 AM |
| lowering problems after lowering | speedsk8er | Styling Modifications | 9 | 03-25-2007 03:28 PM |
| Need some advise !! | bugsy98nb | Miscellaneous Hoo-Ha Archive | 5 | 12-07-2005 04:32 AM |
