CAI Don't Actually Increase Power - NewBeetle.org Forums
Old 09-26-2010, 06:18 PM
You can always turbo it
WI, USA
Default CAI Don't Actually Increase Power
The common misconception is that adding a cold air intake will give you more horsepower. The only thing a CAI gives you is a less impeded intake airflow, and a easier to clean filter element. I added a spectre race cone filter (it has no actual filtration against smaller particles, just big particles) and dynoed it, gained 0 hp, but 3 ft-lbs torque. Then ported out my throttle body and gained 11 hp and 8 ft-lbs torque. Removed my CAI and left the throttle body ported, didn't lose any power when i went back to the stock air box. Another great way to get more power from intake is by porting (not polishing) the intake manifold and port matching the head. This can give you some serious power.
My 2001 VW New Beetle 2.0GLS 4spd AUTO:
Spectre CAI Filter
Throttle Body Porting
Intake Manifold Porting
Shaved Head
High Flow Exhaust Manifold
High Flow Cat Converter
Straight Back Exhaust to Stock Muffler (2.75 inch resonated pipe)
ECU Upgrade
1400 cc Fuel Injectors
High Flow Fuel Pump
Was getting ready for a turbo, then ran out of money. Pushing about 210 horsepower now, dynoed summer 2010. Runs a 13 second quarter at the track. Stock muffler was left so when police checked it, it looked stock. Runs great and I get about 20mpg city!
vDubOne Project
2001 2.0L NB GLS
Dyno: (stock) 122HP
Dyno: (2010) 186HP
13.695 quarter (2009)
Old 09-27-2010, 04:55 AM
marvins_dad's Avatar
I BELIEVE!
Dallas, TX, USA
Car: 2002 DIYCGCC TDI
Was your CAI in the same place as your stock air box or did you take it down to the front grill like a ram air?
Just curious.
Wonder if mine is more efficient that way. It does sound better and I feel it gets cooler air that way.
marvins_dad ~ antoine
Old 09-27-2010, 06:11 AM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
Just curious.
Ahem...
"Cold-air intakes" and "high-flow air filter" FAQ - TDIClub Forums
Seriously, a stock intake and airbox flows more air than a stock or moderately-modded NB would ever need...and you will never see any measurable increase in power ever.
Your water intake does not give you any cooler air or more airflow than what the stock intake would when it pulls air from above the fender liner.
2000 New Beetle GLS TDI
Old 10-10-2010, 03:08 AM
Too Cold NB1.8T's Avatar
Keep It Real
California, USA
Spectre CAI Filter
Shaved Head
ECU Upgrade
High Flow Fuel Pump
Much like any other modifications, the end results depend greatly on the particular drivetrain setup.
Horsepower and torque are two of the possible gains that can usually be revealed with a dyno test, however, all performance gains/losses cannot be measured on a dyno, much like how tranny gearing differences do not add power but can make a significant difference in where the power is placed, thereby greatly changing a vehicles performance attributes.
This is an age old subject cluttered with a multitude of opinions, all you can do is go with what seems to work with your setup.
FYI: This kind of modification will typically yield the lowest (if any) improvement to an N/A engine, better result are normally obtained on a FI engine.
Old 10-16-2010, 04:03 PM
Motown Philly's Avatar
New Member Revisited
Detroit, MI, USA
Car: 2004 NB Convt 1.8T
VdubOne, did you also "Port" your Exhaust Manifold? I'm about to swap my turbo and exhaust manifold, and have been asking myself this for sometime. "if it's worth it to port/polish the exhaust mani?"
Thanks,
Phil
Motown ~ 2004 Cyber Green NB. CONVT. 1.8T
APR Tuned / APR R1 / New South Performace / Silicone Boost / N75 / K&N / Samco TIP-Hose Kit / GPA / 20% Tint / Cactus
Mrs. Motown ~ 2005 Passat GLS 1.8T
APR Tuned / APR R1 / N75 / 35% Tint
Old 10-16-2010, 05:25 PM
LOL! WTF is all of this about? Your stock 2.0 doesn't need any more fuel or air than it already is getting from the factory parts. A 2.0 is a waste of time to mod unless you go forced induction, which will destroy your automatic transmission.
There is no "serious" power to be had from a 2.0 without dropping big bucks on it. Almost every single item on your list is a complete waste of money and time. A guy on VWVortex did a very involved NA build of his 2.0L ABA and it only made 135whp or so, which is fairly impressive in my opinion but for the amount of money he had invested he could have gone turbo.
I don't believe you got 11hp from porting your throttle body at all. I think that's BS unless you have the dyno charts to prove it. I read up on this and all ported throttle bodies seemed to do on the MK4 2.0L is make them run like crap. You're only going to gain power is you identify a major bottleneck (restriction) of the engine and modify accordingly. The throttle body on the MK4 2.0 is the same size as on the 1.8T, and those cars have been pushed well past 350whp with the stock throttle body.
Old 10-29-2010, 12:13 AM
WI, USA
Thanks,
Phil
I found an old exhaust manifold from a junkyard and yes ported it out quite a bit
Old 10-29-2010, 12:17 AM
WI, USA
Yea but you know what is funny, I am probably the only person in a 2.0L AEG running a 13.597 second quarter mile (Summer 2010). I just wanted to be the first to modify the 2.0L engine, I have 142hp at the wheels (Dyno: yet again, Summer 2010). And I do have the dyno charts, AND, Don't try to tell me that I don't know what I am doing, because I do. I also replaced my pistons, totally worth it (no longer burning oil). AND I get about 24 miles per gallon, pretty damn good in my opinion. AND to say about your big bucks, I make a LOT of money each year, and I have 11k dumped in mods here
Old 10-29-2010, 12:19 AM
WI, USA
Also guys, Porting and Polishing actually hurts performance, because people think by porting, then polishing, you will have a smoother flow, when really you want a rough mixture flow of air or exhaust in either manifold. I put this car out on craigslist last week for 13k as a race car, got someone interested already. Thinking of buying a 1.9tdi
Old 10-29-2010, 12:20 AM
WI, USA
And I keep forgetting to comment, I have a limited slip differential installed, totally worth the 700 bucks i dished out for that one
Old 10-29-2010, 04:59 PM
AbuNigel's Avatar
buggin
Bridgeport, CT, USA
Car: 2000 2.0L Red New Beetle GL
ok...sooo let's see the dyno charts...you said you have them..
My 2.0: 'Lil Red'
Old 10-29-2010, 05:31 PM
Looking very forward to this.
Old 10-29-2010, 06:54 PM
Opelmania's Avatar
Dubbed Spiderman
Woodstock, IL, USA
Car: 98 2.0 5 Speed
So between the price of the car and the mods you have a 13.5 second $20K NB? For 20K, there is a lot out there that will put way more HP to the wheels and run a lot faster than that. A2000 BMW M5 comes to mind with money left to make it faster. I too am looking forward to this.
Old 10-29-2010, 07:36 PM
NewBeetleMechanic's Avatar
Real life Beetle mechanic
Let me get this straight, your pushing an additional 30 whp with your installed parts? The only 2.0 Beetle I have ever seen get under the 14 mark was a fellow drag racer with a 100 shot of NoS, He pulled a 13.5 on the first run, the second run spit the #2 rod out of the block at the 600 ft. mark.
It also stripped the pinion drive gear completely off when the engine blew.
Where did you find the proper spider gear globe for the diff, cause I gotta know, the stock globe will not take a 95hp increase. I personally know it will turn into a goopy mess.
Old 11-03-2010, 05:13 PM
Opelmania's Avatar
Dubbed Spiderman
Woodstock, IL, USA
Car: 98 2.0 5 Speed
Waiting on dyno sheets and drag slips.
Old 11-25-2010, 11:02 AM
Keep It Real
California, USA
This is not entirely correct, it is true that some rough texture in the intake paths can help with fuel atomization and improved A/F mixture depending on the engine setup, but, when it comes the exhaust side, an engine can definitely benefit from a smoother, flowing internal surface (port & polish or extrude hone...).
ECU Upgrade
Wait a minute, 1400cc injectors on a 2.0L NA engine, WHAT!!... You must have big block size pistons, cams with some crazy lift and duration, a custom head with some serious combustion cambers and a killer software tuner to make this work, not to mention, all of this in front of a VW automatic transmission.
Hmmm, I've gotta be missing something here...
Old 11-25-2010, 05:01 PM
He's a moron. That's the only thing you missed. His car was apparently "stolen" and he never provided any pictures or proof.
Best cai SLOW98NB 1.8 Liter Turbo 20 06-07-2011 10:18 PM
How can I increase my H.P.? zwerglmom 2.0 Liter Gas 87 07-08-2010 04:41 PM
increase HP jcthelight Technical Modifications 3 02-03-2010 06:00 PM
What's The Best Mod For A Totally Stock Turbo S? (for Power Increase) chris22104 1.8 Liter Turbo 9 07-21-2007 05:03 PM
Cai? mindphunk 1.8 Liter Turbo 3 02-23-2006 06:15 PM
