E Brakes light never shuts off - NewBeetle.org Forums
Old 10-18-2010, 09:09 PM
Default E Brakes light never shuts off
My beetles Ebrake light on the dash will not shut off even if the handbrake itself is already all the way down, tried to check it on the back of the tires if its stuck but it is still moving when i raise up the handbrake...its the light that will not turn off.
thank you
Old 10-18-2010, 09:11 PM
HudsonValleyVDub's Avatar
Hudson Valley Area, NY, USA
Car: Techno Blue 01 GLS 5 spd
That light is not just for the E brake. Top off your brake fluid and it'll go out. As the pads wear, and the fluid level goes down, that'll happen. That's what happens on My Nissan Titan pickup.
- Joe
Old 10-18-2010, 09:54 PM
thanks ill try that
Old 10-19-2010, 01:55 AM
gforce1108's Avatar
Port Jervis, NY, USA
Car: 98 Beetle TDI
That's usually about the time the pads need to be replaced. If the pads are really low, don't fill the reservoir (bring it up far enough to make the sensor happy). Otherwise, you'll make a mess when the new pads get installed (if you don't remove some fluid).
98 Beetle TDI sprint 520s, KP39 turbo, fully straight piped My 29th VW
04 Jetta TDI RC3, vnt17/22, FMIC, side exit exhaust.
57 Beetle Oval Window Sunroof
2 powerstrokes, Thing, Fox, Dune Buggy......
Old 10-19-2010, 02:31 AM
Agreed. I just didn't want the OP to think there was a real problem.
Beetle Shuts Off While Driving???????? giink 2.0 Liter Gas 30 02-12-2012 03:20 AM
Engine shuts down, red temperature light on with no flashing Poodlebugz 1.8 Liter Turbo 5 07-07-2010 01:58 AM
Oil Pressure Light Blinks and Alarm When I Hit the Brakes KTOKTO 1.8 Liter Turbo 2 09-16-2009 05:08 PM
Please urgent help : brakes / Front brake pad light Nounours Questions, Issues, Concerns, or Problems with the New Beetle 7 01-18-2007 12:36 AM
