You should have done it while the engine was out, but unless there is a sticker or a receipt saying when it was done you can't be sure. The condition of the belt can be an indicator but I wouldn't rely on it.
There is no way to know for sure. I would just go ahead and replace them, along with the tensioner, roller and stretch bolts.
Thanks, the engine was not all the way out, the prior owner had the clutch replaced, the person that replaced it over tightened the trans mount bolt. A week later the engine dropped loose pulling the left axle apart.
All I did was get a new mount out of a junk yard and a new axle and now I have a good running car. Thanks for the help |
when you do the timing belt and water pump, make sure you get a water pump with a metal impeller. the factory vw pump comes with a plastic imeller that is failure prone.
I swear my real name is not "Wienerdude" 2003 1.8T Beetle ![]() 2001 Jetta 2.0
...I am looking into how hard it is to do this...There is some things I can do, but a lot I can not.Thanks again for any help?? |
You can also get entire timing belt kits from ECSTuning.com which include the metal impeller pump, new bolts, mounts, tensioner, and coolant you need.
Ok, Called a certified Euro Car mechanic that is not at the dealership This is what he said will be needed to do the job and what it will cost.....
![]() water pump with metal impeller timing belt tensioner roller tensioner assembly idler roller accessory drive belt thermostat housing new seals gaskets and bolts plus labor all for $850....am I getting screwed???? ![]() |
850 seems slightly high, but not too astronomical. I paid $450 for mine, but I have a 2.0, so its a bit easier. I will say that you don't necessarily need to do the thermostat. Some people do though. I didn't have it done when I got my work done.
Any way they will warranty the labor if you brought your own parts? You can get kits for just a couple hundred dollars. |
| YES, I did it! - Timing belt, water pump, accessory belt. | antonym | The New Beetle Experience | 22 | 10-11-2011 03:50 AM |
| Water pump, timing belt, tensioner, accessory belt replacement | grumblebunny | 2.0 Liter Gas | 30 | 04-25-2011 04:49 AM |
| Water Pump and Timing Belt??????? | Cooky | 2.0 Liter Gas | 9 | 07-21-2009 08:20 PM |
| Timing belt & Water Pump changed now | fatdaddy | 2.0 Liter Gas | 8 | 03-19-2006 08:14 AM |
| I had Timing belt and Water Pump changed now the Check Engine light | fatdaddy | Questions, Issues, Concerns, or Problems with the New Beetle | 15 | 02-13-2006 02:27 AM |
