Neep Help for HID - NewBeetle.org Forums
Old 11-22-2010, 04:25 AM
Default Neep Help for HID
hi all
I want to put HID on my 2000 Beetle but do I need to buy the HID with canbus? or just anyone HID is ok?
Old 11-22-2010, 12:49 PM
Basher's Avatar
Huskvarna, Sweden
Car: 1999 Techno Blue 2.0
Originally Posted by hiteamz View Post
hi all
A regular (non-canbus) HIS is ok, just make sure it's a H1 replacement kit.
Some ballasts (the high voltage converters) don't work very well with the thin wiring in the NB. This will show in lamps that don't start after cranking and it's due to a voltage drop in the original wires. This should be solved by taking the power supply directly from the battery with a relay. Go to a mechanic if you won't be able to fix this in a decent way yourself. Bad wiring can cause fire.
Due to the older type of projector lenses I think it's good to give the headlights a polish, just to reduce glare a little. You won't really notice the difference yourself, but it's nice to the other drivers.
Old 11-22-2010, 03:59 PM
HudsonValleyVDub's Avatar
Hudson Valley Area, NY, USA
Car: Techno Blue 01 GLS 5 spd
Any good H1 HID conversion kit will do just fine. I use the DDM Tuning kit and they look excellent and work great. You can go to the DDMtuning site for them and they also sell the $13 HID wiring harness for them.
- Joe
HID question DarthBeetle Technical Modifications 18 06-14-2011 07:39 AM
Do I have HID? BlondieeAggiee Questions, Issues, Concerns, or Problems with the New Beetle 5 01-19-2009 06:11 AM
Need HID help iwannagofast Styling Modifications 6 10-02-2008 01:53 PM
HID Help FallinApartBoy Styling Modifications 4 08-27-2008 02:32 AM
HID installation ilovesti Technical Modifications 1 12-25-2006 05:11 AM
