MORAV |
Another way of getting a Homelink unit installed is this: Purchase a visor Homelink module (no visor just the little push button box) off eBay for a few bucks. Be sure to get the mating connector for power. I installed mine under the center panel cover with double stick tape and powered from 12 volts with key on. It may work just a well under the dash somewhere too. Jumpered one of the three push button contacts (using two small wires soldered to the circuit board) and ran these down to the left trim piece opposite the bud base holder. Installed a small Radio Shack normally open push button on the bottom side of this trim piece for operation. Program the unit as normal. But the visor would be better for readily available (re-) programming. OR just power up the unit and stick it under the dash somewhere to access the buttons.
Tom I haven't seen an adult since I was a kid!
58and03beetles: Need an update on this installation of your visor. Were you able to use the Passat visor?
I had posted about basically tucking a "universal" remote away and soldering two wires to the contact points where the original button on the remote contacts within the unit....run the wire to a small pushbutton someplace thats easy to get to and hidden. People do this on their motorcycles and use either existing switches or a separate switch mounted in easy reach.
Id bet it's less engineering, cost and more 007-ish! ![]()
4SEVEN3 |
The concept here is having control of three different items, "home"link (get it?) not just a single garage door opener, and also have it "OEM" in both use and appearance. I'm just going to wait until I stumble across a used one from a NB or go buy am OEM. 58and03beetles got more time on his hands than I do. (lol)
MORAV
Ok heres an update-
to install the passat visor i had to remove the mounting base- even after reshaping the hook on the mounting base, the screw hole was totally off from the one in the car body and would not be able to catch the body. base has visor arm exiting 1/2 forward on a passat so my visor was gonna sit cawkeyed. so i went to the junk yard and found a rolled new beetle convertible and removed the visor base by cutting the arm with large copper snips. i took it home and used a dremel to remove the cone on the visor arm or the passat visor. i then carefully cut a slot and slid in a c clip to retain the visor into the base-its still super snug this way. i got 1 electrical connector and the wires preterminated with the proper electrical connectors, but still need one to connect to the other side in the car, dealer ordered the female side and i needed a male side. so its still in the works. it would be sooo much easier to install an actual convertible visor bought from the dealer parts counter- but at a cost of 295.00 no thank you- that doesnt include the connnectors and wires at an additional cost of 45.00- stealership 1, me 0. im happy i bought a passat visor shipped to me for 65 off of ebay even though it is more work. anyhow, i tested the opener connected to my battery in the mean time and it works great! still not done with this install |
Sure sounds like having the convertible visor is the best way. Hope your efforts to modify the Passat visor works well for you. I can't and won't pay $295 for one either. Just don't need it that bad. Do you think one from a NB sedan would have fit correctly? Good Luck
Well, I just nailed a set off eBay for an NB, so I'll be able to let everyone know about interchange with NBC. I'm really certain these are going to be flannel gray, and not the pearl gray I'm needing, but at least I'll know about the fitment. lol
Anybody need a set for an NB in flannel gray, I'm gonna' have them if I decide not to resurrect my '02NBT! lmao According to LKQ the fitment is '00 - '10 Here MORAV Last edited by MyOtherRidesAVette; 01-24-2011 at 02:02 AM.. |
hey Rog,
those are pearl white! you scored the correct ones! im curious to see if the bases are the same ones as a NBC? thats the same wrecking yard i bought my passat visors from! very impressed with their packaging- they were vaccuum sealed in plastic! |
What makes you think so about the pearl white/pearl gray. I couldn't tell anything by the interior code LKQ gave, and I thought the pearl surround came about as a standard surround color regardless of the interior color with the advent of the NBC in '03. I can not phathom that they would have two different mounts, or even two different parts, unless it is a color unique to the NBC otherwise there would be line problems, and additional parts inventory when not required. I figured you or Duffy might have been bidding against me on these (lol)! I also want to believe that the right one is a p&p, with no reworking of the harness required. Since I live in a Hotel when I'm in Houston, I'm not sure how I'm going to test this until the first time the Bug goes North!
| WTB: Sun Visor with Homelink (garage door opener) for a Convertible Color Tan | Duffy | Parts and Accessories | 24 | 04-18-2012 11:05 AM |
| 2007 New Beetle Convertible Sun Visor | claudiadiaz0517 | Parts and Accessories | 2 | 09-17-2011 03:12 PM |
| PASSAT: The Nice Car That Picks You Up When Your Beetle Breaks Down! | chephron | Photos: Other Rides | 70 | 09-02-2011 02:27 AM |
| FS: Tan Homelink visor | dieselgti | Market Place Archives | 9 | 06-26-2007 10:32 PM |
| 00 1.8T passat oil filter work in a 03 1.8t Beetle? | tuner-automotive | 1.8 Liter Turbo | 7 | 11-25-2006 04:45 AM |
