Is there a way to turn off headlights while driving? - NewBeetle.org Forums
Old 12-29-2010, 10:05 PM
Default Is there a way to turn off headlights while driving?
I'm going to an event where I'll need to drive along a well lit path at night and they recommend turning off headlights. Is there a way to do this? Thanks.
It's a 2005 convertible.
Old 12-29-2010, 10:35 PM
MyOtherRidesAVette's Avatar
Exclamation This should be helpful!
You're referring to what are called DRL (daylite running lights), they exist in America because of laws in Canada. They either have to be disabled, or with the use of a Euro switch turned off, however, with the Euro switch, your running lights and marker lights will still be on as it allows for separate control of those and your headlights. I have to review the switch specs to check on independent operation of the DRLs but I doubt it. Here's the link to buy the switch. It is a very easy p&p, no screws, plugs, wires, etc to fool with.
Home Page > ES#8602 European Headlight Switch (Euroswitch) - 1C0941531AKOS
I know I have read threads about disabling the URLs but I have no idea of what is involved. There is a lot of controversy about their use and it's argued on here all the time.
MORAV
In der Automobil-Scheune
Old 12-29-2010, 10:47 PM
Tico4Life's Avatar
treiber gefunden
UNION, NJ, USA
Here is a DIY thread, hope it helps
Disabling Daily Runing Lights (DRL's) - How-To
—Ambrose Redmoon
Old 12-29-2010, 11:03 PM
Beat me to it
In addition to that how to, you can also break off that prong vs. taping it over. Just be mindful that once you break it off, you're forever stuck without your DRL's.
I have a Euro switch and you still have to disable the DRL's, but like MORAV said, the DRL's will be gone, and you can rock your fog lights without the DRL's messing up the cool factor. However your marker lights will remain on.
Old 12-29-2010, 11:31 PM
Tico4Life's Avatar
treiber gefunden
UNION, NJ, USA
Originally Posted by scarabY2k View Post
Beat me to it
Sorry mate, I have been burning my eyebrows on all the good stuff you guys have posted in the past and I have to put it to good use some how LOL next one is yours!
Old 12-29-2010, 11:49 PM
Duffy's Avatar
Duffy II
Jonesboro, AR, USA
Car: 2009 NBC Harvest Moon
Simple and quick fix: Pull the hand brake up ONE notch. Walla, the lights go out!
Tom
Old 12-30-2010, 12:10 AM
Appears Duffy has taken the lead and upstaged you both!
Old 12-30-2010, 12:54 AM
Tico4Life's Avatar
treiber gefunden
UNION, NJ, USA
Oh well, I had my 2 min of glory!!! :roflmao
Old 12-30-2010, 01:17 AM
And i'm left looking like
Old 12-30-2010, 02:18 PM
Zann's Avatar
HP Technician
Macon, GA,
Car: 2002 New Beetle Turbo S
Couldn't do that on mine as my brake is strung so tight one click and my car doesn't move
Old 12-30-2010, 10:52 PM
Hence doing it the way I mentioned. It's an easy mod.
Old 12-30-2010, 11:06 PM
Opelmania's Avatar
Dubbed Spiderman
Woodstock, IL, USA
Car: 98 2.0 5 Speed
Taping it didn't work on mine and I didn't want to break the tab on the switch so I just cut the wire to that tab. (purlple I think). That way if you want to, resplice with a butt connector.
Old 12-31-2010, 12:21 AM
Fl_bug's Avatar
Catch me riding s00ty!
Miami, FL, USA
All you had to do was bend the pin on the headlight switch.... If you wanted DRLs back, all you had to do was unbend it
Old 12-31-2010, 02:35 PM
Tioga, TX, USA
Car: NB 2000 TDI
they are adjustable you know
Old 12-31-2010, 02:49 PM
Opelmania's Avatar
Dubbed Spiderman
Woodstock, IL, USA
Car: 98 2.0 5 Speed
Bending twice = breakdown on thin metal = broken tab possibly. I'm a building engineer so I don't like bending pins on switches.
Old 12-31-2010, 03:51 PM
Ditto! Maybe tape on the contacts as someone suggested. The break thing or the Euro switch.
MORAV
Old 12-31-2010, 04:32 PM
Fl_bug's Avatar
Miami, FL, USA
MORAV
Euroswitch doesn't disable DRLs. It just gives the option for parking/city lights.... I have a euroswitch, and I also had to bend the pins on it to disable my DRLs.
Old 12-31-2010, 09:02 PM
No, I know, I stated that in my first post to the thread suggesting the Euro Switch as one way to not have the headlights on.
MORAV
Old 12-31-2010, 10:55 PM
Too Cold NB1.8T's Avatar
Keep It Real
California, USA
DRL's are great for those twits who drive like fools, don't pay attention cause they are too busy talking about nothing on their cell phone and/or regularly forget to turn their headlights on when it starts getting dark, great that is, for the "other driver" who needs to see them in order to avoid them.
For the good drivers they are nothing more than a bulb life shortener, I installed the Euro headlight switch years ago, this added some old school car feature including the 86ing of the DRL's, you could not pay me to reconnect them...
Old 01-01-2011, 02:51 AM
Oh, I don't know about old school, VW's the only car I've ever owned with such a stupid two (well three) position headlight switch. My GMs have a DRL temp defeat feature, individual running/headlight positions and fogs are still seperate. But I'm sure, the concept was developed for the people you are referring to.
MORAV
headlights wont turn off :( daisybug2002 Questions, Issues, Concerns, or Problems with the New Beetle 2 03-12-2009 12:16 AM
Headlights driving me CRAZY GL8289 Questions, Issues, Concerns, or Problems with the New Beetle 5 03-06-2009 02:38 PM
Both Headlights won't turn on mj1234 Questions, Issues, Concerns, or Problems with the New Beetle 9 10-05-2007 02:17 PM
Another brake light question, won't turn on when driving! kickson Questions, Issues, Concerns, or Problems with the New Beetle 9 03-16-2007 03:26 PM
Making my turn signals into headlights dvious Technical Modifications 9 10-03-2006 08:31 PM
