My 2.0: 'Lil Red' |
you need to lower your perches if they are adjustable.
if you canot lower the perches, you need to compress the spring some to install the shock to the rear axle beam.
Most auto parts stores have loaner tools available.
are your rear jack stands sitting on the rear axle beam? are the new springs thicker, or longer than regular ones (like Jetta wagon springs)
what specific pieces are you trying to install? photos might help. |
I have 4 jack stands, one at each corner's jacking point.
The springs are shorter than stock, I'm pretty sure, they are Rokkors. They might be thicker, but we did get them installed no problem the first time around. The only differences between that time and this time is: That time: front wheels were on the ground no perches installed, so the springs were about an inch or so lower This time: entire car on jack stands perches in I was just thinking earlier, I did put the helpers/perches in (as in, I screwed them to the control arm) and then put the springs on top. When I tried to jack one side up without the other side's spring in, i could get it high enough to put in the bolt, but there wasn't room on the other side to get the spring in. Maybe if I put the spring, helper and perch in all as one unit I would have room to do so when the other side has been jacked up and the bolt inserted again. |
| rear suspension | newtobeetles | 2.0 Liter Gas | 8 | 10-01-2010 11:09 AM |
| Rear suspension thump | karmann72 | Questions, Issues, Concerns, or Problems with the New Beetle | 4 | 09-29-2009 12:36 AM |
| Suspension Noise After Coilover Install | 5t3v3 | Technical Modifications | 25 | 03-28-2008 09:31 PM |
| WTB Rear suspension | jbarham | Market Place Archives | 12 | 01-19-2007 03:09 PM |
| beetle pics link before suspension install | degny21 | Technical Modifications | 0 | 01-05-2006 05:20 AM |
