01-12-2011, 01:06 AM
I Am Breitbart
VCDS does not do programming, you can do adaptations within the stock parameters, but not programming. There are apps (Android and i*hone) that can read ECU inputs and check/clear OBD codes, but thats it.
For those wondering, Ross Tech does have a product in development that will allow you to use VCDS (either on a laptop or smartphone) wirelessly via WIFI. It will be available as an upgrade to all registered VCDS owners.
2000 New Beetle GLS TDI
