Headlight looks a bit foggy. need to replace, but from where? - NewBeetle.org Forums
Old 01-17-2011, 07:39 PM
Default Headlight looks a bit foggy. need to replace, but from where?
Hello everyone.
I hope I've posted this thread in the correct forum section. I looked for a troubleshooting section, but couldn't find it.
Anyways, I own a 2006 Volkswagen Beetle (2.5L 5 cylinder engine, Manual Transmission). Just today I walked into my garage and noticed that the passenger side headlight of my Beetle looked a bit opaque, more than the driver side, which was transparent-looking. With a closer inspection, I noticed that there was also a tiny fracture (inch-long) in the headlight assembly, running vertically from the base of the light. Could this fracture have allowed moisture to enter the light and cause the fogginess?
I've decided to just simply replace the light, although I'm sure there are ways to restore the light. I'm going to purchase an aftermarket version online and after doing some browsing around I've narrowed it down to two vendors that I may buy from. The only problem now is, I'm a bit suspicious that one of the vendors may be illegitimate, since the difference in prices of the headlight between the two sites is somewhat significant. Has anyone used either of these sites and can verify that they're indeed legitimate? Thanks in advance.
Volkswagen Beetle Headlight > AutoLightCenter.com
or
Volkswagen Beetle - New Headlight HALOGEN - AM Autoparts
Old 01-17-2011, 08:25 PM
2004NBTURBOS's Avatar
Peace Love & T.o.D.
Ocean View, DE, USA
Car: 1st 2000 GLX now 03.5 TS
I can't help in the vendor issue, but my 2000GLX had a crack in the lens that would allow moisture in. It would dry out by itself, so I waited till it was dry then took superglue and filled in the crack.You could hardly notice it. It lasted 2 years. It may still be holding for the person who bought it off of me.
Foggy headlight lens saved2 Technical Modifications 1 08-23-2009 05:21 AM
Replace headlight on 06 bug with LED one Shaolen Styling Modifications 2 03-10-2009 12:19 PM
$300 to replace oil pan, HELP!!!!! beetlebgyrl Questions, Issues, Concerns, or Problems with the New Beetle 21 05-09-2007 09:12 AM
Anyone replace the MAF themselves? shuffs 2.0 Liter Gas 7 12-12-2005 11:53 PM
What if I don't replace the MAF? shuffs 2.0 Liter Gas 6 11-23-2005 08:02 AM
