Catalytic converter? - NewBeetle.org Forums
Old 01-24-2011, 02:43 AM
Question Catalytic converter?
I have a 99 beetle with the 2.0 and was curious if it would goof with the ecu and kick up check engine codes if I were to remove the Catalytic converter?
Old 01-25-2011, 04:06 PM
Geilenkirchen, Germany
Car: 02 Mercedes SLK32
Yes, with little performance gain, if any. I went that route and finally got tired of the check engine light. I tried several "cheaters" on the aft O2 sensor and couldn't get it to stay off.
If you just need to replace yours cause it's bad, you can do like I did. I picked up a Magnaflow and had it welded in for MUCH cheaper than an OEM one. Since I had a 3" exhaust, I used this: Magnaflow 94139 Single Sensor Cat 3" In/Out
They come in any size inlet/exhaust port.
Old 02-01-2011, 05:26 PM
Beetle1.8turbo's Avatar
Detroit, D-Town, USA
Car: 2001 *1.8 turbo
What size is the original?
Catalytic Converter oceanjoe89 2.0 Liter Gas 11 11-12-2009 07:58 PM
catalytic converter help slugbugminneapolis 2.0 Liter Gas 13 02-11-2009 02:42 AM
Catalytic Converter...Thanks greenbastard 2.0 Liter Gas 7 06-23-2008 12:29 AM
Catalytic Converter my99beetle 2.0 Liter Gas 13 04-09-2008 05:13 AM
Catalytic Converter KNEWBUG New Beetle Convertible 8 09-14-2007 02:04 AM
