Hi
I have some problems with my engine. In Germany there are not many 2.0 Turbo on the street, so i ask here for some help. The engine stopped working. We searched for the mistake in the electric and the engine. Mechanic all correct, but the cable from my air-mass sensor is broken. Please, if someoe have the 2.0 turbo like me, could you take of the cable from the air-mass-sensor for an moment and write if the engine stops or not? I repaired the cable, the engine works. But the feeling when i will get the full power is not so good. The engine cogs... Maybe some other sensors are working not correctly, the Lambda-sensor 1 is changed but nothing is better. Greetings from Germany Christian (my english is not as good as it shoult be, please excuse me...) |
We don't have the 2.0T New Beetle here in the states. We have the 1.8L Turbo instead.
Do you have a check engine light on?
OK, then must be something wrong. If at my car the MAF is unplugged, the engine stops. Maybe the potentiometer of the choke-valve is broken that the motormanagement can't get informations. Normaly if the MAF is unplugged the management will get informations from the choke-valve.
Shurely i worked with the VAG-COM: the mixture is too lean and low signal Lambda 1: Lambda 1 is changed... Now i change the MAF and then eventually the choke-valve. Thank you, SMG @Smileybug: Never Volkswagen was building an 2.0 8V Turbo Beetle. I know that, i work in the Factory for over 26 years in Germany!!! Some Tuning-men, TTP for example, created an turbo kit for this lovely engine. Most of this kits went over the atlantic, only a few kits are here in Germany. So i know no german 2.0 turbo driver at all. Christian Last edited by chrissy; 01-28-2011 at 07:15 AM.. |
| 1.8 Turbo problems | ej2005 | 1.8 Liter Turbo | 15 | 05-26-2010 10:55 AM |
| turbo problems | tnbeetle | 1.8 Liter Turbo | 14 | 07-25-2008 12:38 AM |
| Turbo S Problems | ETBUG | 1.8 Liter Turbo | 9 | 02-02-2008 07:15 AM |
| Turbo S (problems)please help... | uf_gators | 1.8 Liter Turbo | 33 | 10-24-2007 06:36 PM |
| Having problems with Turbo | jodiebrn | 1.8 Liter Turbo | 2 | 10-18-2006 01:34 AM |
