RHD Swap - NewBeetle.org Forums
Old 02-25-2011, 04:38 PM
knownaschubs's Avatar
Sandy Eggo, Cali,
Default RHD Swap
just wondering, has anyone done the Right hand drive conversion to their NB? I will be doing a VR swap within the next year and since im going from automatic to stick and cutting up the fire wall for the clutch assembly i was thinking of doing the RHD swap while everything is in pieces.
Old 04-23-2012, 07:56 AM
Cooky's Avatar
Every one calls me Fuzzy
Loudon, TN, USA
Car: 1998 VW New Beetle and 2000 Jeep Wrangler
i am curious about this too. I have always loved the look of a right hand drive. I am an a student to become an engineer and I know that VWs are sold all over the world. This means that the dash structure should be about the same so that when building at factory it will be the same thing just depends what where it is going to be what goes where. This saves in build time and saves because the stamps that make the parts are the same. I guess if no one knows i will just have to take the dash out and take a look
2k12 TOD
Camping At the Top 2k12
"slow is smooth, smooth is fast"
Old 04-23-2012, 01:44 PM
Cutting up the firewall for clutch install? Just did a swap to manual and no hacking up needed. Already provisions for the clutch.
Also not sure on the legality of RHD. You would have to check into that.
Sent from my SCH-I405 using AutoGuide.Com Free App
8 valve so16 valve swap and 1.8t swap ?'s Slow_bug Engine Swaps 0 11-11-2010 11:04 PM
swap? or not? masteramd09 Technical Modifications 3 01-31-2010 11:06 AM
99 2.0 gas swap for ??? huck731 Engine Swaps 13 10-21-2009 01:45 PM
2.0 to TDI swap macdave 1.9 Liter TDI 3 05-25-2008 02:09 AM
TDi swap? Steinola Engine Swaps 37 05-18-2007 02:15 PM
