Sway Bar Help - NewBeetle.org Forums
Old 02-27-2011, 08:01 PM
CT,
Car: 2002 Snap Orange color concept 1.8t
Default Sway Bar Help
Hi all. I have my car lowered on B&Gs and the passenger axle has taken a beating from rubbing. I already tried adjustable end links and this did not solve the problem. I am ready to buy an aftermarket front sway bar to fix my clearance problem. I was looking at the neuspeed but they say it cannot be used with b&g coilovers. Are there any other brands I can use?
2002 5 spd Snap Orange color concept
"Six billion people in the world. Six billion souls. And sometimes -- all you need is one."
Old 02-27-2011, 09:35 PM
Wingnut_rb's Avatar
Kennewick, WA, USA
Car: 03 Red Turbo S, 66 Ford Galaxie
Did you look at the adjustable end links from ECS? They come with 3 different lengths of adjustment bolts. The ones you had may have not had enough length to them to get you where you need. ECS has a video on their site. Just a thought....
Old 03-02-2011, 11:06 AM
Fl_bug's Avatar
Catch me riding s00ty!
Miami, FL, USA
Don't waste your time with adjustable endlinks. Either take your swaybar out or replace it with one that has a larger "horseshoe" that goes over the axle. When you look at aftermarket swaybars, get the one that says "For use when lowering the car more than 1.4 inches".
Here is one good example. Its a little pricy, but you can find a used one on Ebay or Vwvortex for much cheaper.
Old 03-02-2011, 11:38 PM
CT,
I heard the H&Rs still rub on occasion. My car is lowered around 2.5-3 inches so I would probably get one that goes under the axle like the autotech. I won't buy more endlinks, I have mine shortened completely and there is a deep groove in my axle. I guess I'll just have to spend the money on an autotech. I just have to find out if I'm hitting subframe or not
Old 03-03-2011, 12:26 AM
Just take the swaybar out. I don't miss it.
Sway bar bushings jbremount 1.8 Liter Turbo 7 11-22-2010 03:11 AM
sway bar help mat3833 Technical Modifications 6 11-03-2008 02:43 AM
O-bar /rear sway bar/ NEW BeetleRobb Market Place Archives 18 06-28-2008 06:14 PM
WTB Sway Bars TurboSChick Parts and Accessories 2 05-18-2008 04:50 AM
Sway bar bushings jc918t 1.8 Liter Turbo 4 06-07-2007 03:05 AM
