Lowering question - NewBeetle.org Forums
Old 03-10-2011, 01:32 AM
Default Lowering question
Ok I can get some lowering springs from a buddy for cheap real cheap (almost free). Will eibach springs for a 2001 vw gti fit on my 2000 beetle?
Old 03-10-2011, 01:33 AM
Depends if they are for a VR6 GTI or a 1.8T GTI.
Old 03-10-2011, 02:26 AM
It is a vr6
Old 03-10-2011, 02:28 AM
What engine is in your NB?
Old 03-10-2011, 02:37 AM
I have the 2.0....thanks for the reply
Won't work.
Old 03-10-2011, 07:23 AM
TDI_bubble's Avatar
Whats different about them? I thought front vr6 springs with wagon rear springs gives a lift, so why wouldn't drops work with differing rates? I've seen the only difference is the spring rates and dot color codes.
VR6 uses the same strut doesn't it?
Old 03-10-2011, 08:43 AM
Fowvay's Avatar
Moderation in Moderation
Berea, OH, USA
They will fit perfectly fine. The VR6 springs are a slightly higher rate so the front won't be lowered as much on your lighter 2.0 vs the VR6. Not a big deal if you aren't trying to go LOW.
Not ideal, sure but for the price you paid.. so what?
Old 03-10-2011, 04:37 PM
OK so it will work but just not lower that much? I believe it lowers about 1.5"< so how much you think it will lower?....Thanks
Old 03-10-2011, 07:21 PM
Fowvay's Avatar
Berea, OH, USA
I just did some comparing and I think probably 1.1 inches. Which is what Eibach lists for the vert.
Old 03-10-2011, 07:24 PM
Spring rates will be higher on the VR6 springs so the ride will be a little harsher with a lighter front end. If there was no noticeable difference they wouldn't make 4cyl and 6cyl versions of the same springs. Also keep in mind that lowering springs will kill your stock shocks pretty quickly. My stock rear shocks blew out about a month after I lowered my TDI. I had new Koni Yellows sitting here but it rode fine for a while so I didn't bother installing them until the stock rears blew out.
Lowering Beetlebomb Questions, Issues, Concerns, or Problems with the New Beetle 7 12-14-2009 03:48 PM
lowering problems after lowering speedsk8er Styling Modifications 9 03-25-2007 03:28 PM
Why I don't believe in lowering... noR Technical Modifications 30 03-31-2006 03:29 AM
Another lowering question gilligan Technical Modifications 3 02-09-2006 11:18 PM
Lowering the NB!!! sickboy21 Styling Modifications 14 10-18-2005 06:51 PM
