Suspension overhaul and lift question - NewBeetle.org Forums
Old 03-11-2011, 12:58 PM
Default Suspension overhaul and lift question
I decided to replace all suspension in my newly acquired beetle. Everything thumps and clunks and the car is stiff as if there is no suspension at all. It only has 55K but it is built in 1998 and nothing has been replaced. I am thinking of this kit of shocks for $275 at GAP:
GermanAutoParts.com
I want to use this opportunity to lift the beetle at the same time with metalnerd 2" kit. Will these shocks have enough room, or if not, which ones should I get?
Should I replace coil springs unless they are broken? Thank you
Old 03-11-2011, 02:14 PM
Palmettoguy's Avatar
6 Is Better Than 5 ;)
Boston, MA, USA
Car: 2002 Blk TS
They should work w/ no probs. I have a 2" Metal nerd lift kit and jetta wagon springs. I ran into the problem of the rear shocks topping out because I was riding to high in the back, but that was due to taller springs.
Old 03-11-2011, 04:02 PM
doublebarrel's Avatar
Irving, TX, USA
Car: 2000 gls tdi
Go to tdiclub.com for a lot of info on lifting your car.Lots of good info there
Old 03-11-2011, 06:02 PM
Raab_Himself's Avatar
now i want to lift a bug.....dang it you guize!!!!
2002 Turbo S "Ferdinand"
runner-up @ hot vws drag day I
quickest r/t winner @ hot vws drag day II
Old 03-11-2011, 06:12 PM
Boston, MA, USA
Car: 2002 Blk TS
Here's a link to my lifted 99
Moe
NBC 06 Suspension question Barrette New Beetle Convertible 0 04-05-2010 12:42 AM
Suspension parts question MichelleRoze Questions, Issues, Concerns, or Problems with the New Beetle 16 03-01-2010 06:17 PM
suspension question MichelleRoze Technical Modifications 7 09-21-2009 06:05 PM
Wheel & Suspension Question raiderbug Styling Modifications 0 05-04-2007 06:26 AM
suspension question blkdub Technical Modifications 1 05-01-2006 01:37 AM
