Window drop disable! - NewBeetle.org Forums
Old 03-30-2011, 10:58 PM
robbiesgirl's Avatar
by the beach, SC,
Car: 2005 Aquarius Blue Turbo "Vert"
Default Window drop disable!
Hello again,
since y'all are so informative... I have tried to do a search and found numerous threads on this. I don;t have any issue with my windows dropping on my NBC but I can foresee a very expensive future with this. Can anyone tell me the reasoning why the "verts" do this and if it is of any importance? If it is not needed and dosen't pinch the top when open and closing the doors then I have to wonder if there is a fuse that can control this and can it be disabled? any thoughts? I just feel that the poor little windows are really getting a workout!! Thanks so much!
"ARIEL" - 05 "Vert" NB (Baby Bug Blue)
2001 Land Rover Discovery - Green (aka - Money-Pit)
"Avalanche" - 1999 Porsche Boxster (Hubby's Baby) - White
1966 Pontiac GTO (unrestored-showroom condition) - Candlelight Creme
2001 Bourget Fat Daddy Chopper - Purple Custom
Old 03-30-2011, 11:12 PM
Tico4Life's Avatar
treiber gefunden
UNION, NJ, USA
Not sure I understand what you mean by window dropping. Do you mean when you put the top down they drop a couple of inches?
—Ambrose Redmoon
Old 03-31-2011, 12:24 AM
Duffy's Avatar
Duffy II
Jonesboro, AR, USA
Car: 2009 NBC Harvest Moon
The window drops so when opening a door the window will clear the upper top gasket seal. The drop prevents damage to the seal (tops are expensive to replace) and perhaps the window too. When opening either convertible door, always pause a second or two after pulling either the inside or outside handles before opening the door. I know of no way of defeating this nor would it be advised to do so. If the window doesn't dorp have it serviced to find cause.
Tom
Old 03-31-2011, 12:26 AM
MyOtherRidesAVette's Avatar
Thumbs down
I'm assuming you are referring to the window drop of about 1/4". That is so the window doesn't catch on, or drag the top. It is necessary. Also, haven't read here where anyone has had a problem with this particular function. Lots of other door and window issues, but this doesn't seem to be one of them.
MORAV
In der Automobil-Scheune
Old 03-31-2011, 12:46 AM
by the beach, SC,
gotcha, thanks everyone. I just thought it was somethin' fancy that didn't need to be done all the time when I open either of the doors. I wasn't sure if the constant up/down adds to the regulator problem. Thanks again for all your quick responses!!
Old 03-31-2011, 12:56 AM
Tico4Life's Avatar
treiber gefunden
UNION, NJ, USA
NP, it is not the window drop that damages the window regulators and motors, its the poor quality plastic cr@p they are made of.
Enjoy your rag top with no guilt or worries about the windows
Old 03-31-2011, 02:08 AM
by the beach, SC,
aahh yes the little plastic "clips". The 8th wonder of the world.
Old 07-05-2011, 06:17 AM
Our '05 DOES have a problem with the window drop. They drop for just a second, then run right back up & you can't close the doors. If you use the key to lock the doors, they will drop & remain down as you close the door. They used to do it occasionally, now they do it almost every time. Stealership wants hundreds to "diagnose".
Any suggestions?...
TS DRL disable? mat3833 Technical Modifications 35 07-30-2008 08:03 PM
Key Fob + Window drop sb_beetle Technical Modifications 0 05-27-2008 12:23 AM
Window drop/top damage issue update!! blackonblack New Beetle Convertible 12 06-04-2006 04:52 PM
Window Drop ? blackonblack New Beetle Convertible 1 12-23-2005 06:08 AM
Question re: window drop schen72 New Beetle Convertible 8 12-13-2005 04:22 AM
