Wipers... - NewBeetle.org Forums
Old 02-05-2006, 07:24 PM
rcyRegistered Member rcy is offline
Save a horse, ride a....
Burlington, Ontario, Canada
Car: 2000 GLS, silver arrow
Default Wipers...
not sure if this is considered a technical mod, but I've been looking for a better wiper..anyone have experience with these?
http://www.boschautoparts.co.uk/pcWipe5.asp?c=2&d=1
I like the fact that they have an integrated spoiler design because I've tried this type of wiper..
http://images.canadiantire.ca/media/...0_CC_3b443.jpg
and found that it lifted off the windshield at higher speeds as there is no integrated spoiler.
Old 02-05-2006, 07:31 PM
r0nd3L's Avatar
Me Gusta!
Lombard, IL, USA
Car: 2003 Turbo S
I have Valeo Ultimate Wiper Blades that is basicaly same thing as the one you pointed out and so far I'm impressed with them. Driving high speed I never noticed them being lifted and they clean very nicely. Also look much nicer than those bulky types.
Click here to find more info.
2003 VW Turbo S Platinum Grey
Old 02-06-2006, 03:54 AM
Pelican18TQA4's Avatar
CRAZ4VW
Hatboro, PA, USA
Car: '08 BMW 128i coupe
I'd recommend either the Valeo blades mentioned above or the Bosch Icon wiperblades, which are essentially the same exact thing, just made by Bosch instead of Valeo. They're not exactly cheap, but well worth the money in my opinion!
'10 GTI 2-door | '08 BMW 128i coupe | '07 GTI 4-door | '02 Golf GL TDI
Old 02-06-2006, 11:59 AM
Porkchop's Avatar
a.k.a. porkchopzz4
Cartersville, GA, USA
Car: '00 Silver GLS 2.0L auto
Allow me to rant about Bosch for a moment:
I used to be the biggest fan of Bosch wiper blades. I would spend the extra money on the gold box blades. But now I have a scraped up windshield on the bug. The "bridge" that holds the plastic clippy thing is very narrow and just pressed from the same piece of metal as the whole blade frame. Apparently the side to side movement of blade during operation fatigues this thin piece of metal and it breaks eventually. I've had this happen twice, the 2nd time scraping the window up with the wiper arm.
So I switched to Trico Teflon which has a heavy duty thick rivet which has held up well for almost 2 years now. The Bosch blades would only last a few months.
So I still run Bosch on my aircooled VW - mostly because I think the short blades aren't affected by the metal fatigue issue. But I will never run them on the NB again.
So whichever blade you choose, look at this crucial part and be sure it looks heavy duty.
Old 02-06-2006, 12:43 PM
FineExampl's Avatar
Poopship Destroyer
Edison, Dirty Jersey, USA
Me personally, i'd like to know if the drivers side wiper arm will work on the passenger side. If so, i'll take a second one so my arms match.
This also reminds me, how often do you change wiper blades?? I never did figure it out. I used to just change them when fell apart. Especially on my Eldorado.
Ya know, in rain i hardly use my wipers. I use rainX washer juice and with the aerodynamics of the windscreen the water just moves out of the way on it's own.
RCY...this is a good thread. Good job!
LOOK AT MY Bug!!!!
Old 02-06-2006, 03:12 PM
oneighturbo's Avatar
Decatur, GA, USA
Car: 2000 1.8T GLX
i have the Valeo's on my NB and the Icons on my wifes CRV.
I'd go with the Icons!!!
oneighturbo.com | flickr | XBL: oneighturbo | beaman
GIAC | O.Z | TOYO | KONI | EIBACH | GHL | VF ENGINEERING | O-Bar | FORGE | and of course VW
Old 02-06-2006, 03:30 PM
boriquais's Avatar
Still bugging
mt. rainier, MD, USA
Car: '02 Audi S4' '02 Turbo S Black' '99 Uni-Red "Diablita" RIP
Thumbs up i bosch
I use the Bosch icon blades. My first impressions where not good. The reason i say that is because i noticed that the outer portions of the blade didn’t exactly make contact on the windshield. I was skeptical. Then after a few days and really rainy ones i became a believer. I love the way they wipe and work at speed. I recommend them
"0-60 doesn't matter since the speed limit says 25mph and your in a construction zone" said the officer! "but 0-25 does" I said.
See Diablita for yourself.
Old 10-03-2006, 02:27 AM
Pittsburgh, PA,
Car: 2002 NB TDI White 5-speed
Hi folks! Is there really a problem with the passenger side Valeos or Bosch Icons? Here's what Tirerack says:
21" PIAA Curved Super SiliconeWiper Blade Product Details
Notes: 21" Driver side curved wiper. 21" Passenger side curved wiper. Price: $22.00 (each)
21" Valeo Ultimate Wiper Blade(EA)
Product Details
Notes: 21" Driver side wiper. 21" Passenger side wiper. This application will work on either the driver or passenger side of vehicle. Wipers are sold individually. PLEASE NOTE: The passenger side OE wiper has a curved backbone to conform to the contour of the windshield. The Valeo wipers are not curved & may not make full contact on the far edge of the windshield
Bean juice on the tank!
What is biodiesel? www.biodiesel.org, http://www.eere.energy.gov/afdc/altfuel/biodiesel.html
Where can I get some? http://forums.biodieselnow.com/
Old 10-28-2006, 12:19 AM
Pittsburgh, PA,
Default Bosch Icon 25% Off at Advance Auto for October 2006
I got the Bosch ICON and they are truly great. They fit right in and take two minutes to install.
Advance Auto has a special for the month of October, 2006, with all wipers at 25% off. So you can get the Bosch Icons for about $15 each. The computer lists both 20 and 21" sizes, but get the 21".
Thanks for the recommendations here!
Old 10-28-2006, 02:41 AM
CRAZ4VW
Hatboro, PA, USA
21" is the factory wiper size, driver's and passenger's sides. I have a 22" blade on the driver's side and a 21" blade on the passenger's side. Gives slightly better coverage on the driver's side IMO.
Old 10-28-2006, 04:59 AM
SilverSportNOLA's Avatar
Faster Than Katrina
Formerly New Orleans, LA, USA
Car: 01 Sport
I had the Bosch Aero blades on my car when I bought it and I refilled it once, last year at DFW New Beetle Roundup I noticed one of them had disassembled itself and left a nice mark on my windsheild. I replaced with the New VW Part blades, and changed those this weekend. I just installed the new Anco Aero blades, not the cheaper AeroAdvantage, the ones that are like $20 each. I like them, but I don't use them a lot, I am a firm RainX believer.
Passat Aero Wipers Bef Styling Modifications 33 08-18-2007 03:15 AM
Snow Wipers FineExampl Questions, Issues, Concerns, or Problems with the New Beetle 13 01-12-2006 03:03 PM
