Hi, I'm new here.
We just got a 1999 beetle. When the AC compressor is turned on, the idle drops and the engine shakes alot. Driving is fine, but when coming to a stop....it's not. I know the car is supposed to compensate air value's when the AC is turned on, I don't think it's doing it. So, how to figure it out? Can I just raise the Idle? How do you raise it?? Is there a "how to" site where someone has these things? |
I think that is a substantial drop in rpm, more than it should be, but maybe not. I don't know if there is a computer that should compensate for the compressor or not. The clutch could be trying to seize or dragging. Any stronger noise coming from the compressor than normal. And I'm sorry, a control valve for what?
That is rather fishy. The idle can drop, but only down to like 700-750 or so.
depending on the mileage you have Do you know the last time the spark plugs were changed? Are all the vacuum lines good? Has the throttle body ever been cleaned? How old is the fuel filter? This sounds to me like you need a tune up.
I noticed the last time my coil packs were swapped for the latest revision under the warranty recall; that my beetle seemed much less affected by the a/c being on (still affects power but it used to be way worse 1.8T).... just thought I would mention that...; with such a drop in rpm, I wonder if the compressor is failing and is causing a big drag (load) on the engine. Something is definitely, not right; what do the belts and compressor sound like when the clutch engages?
POST #4
I have one regular poster who seems to follow me around affirming my posts almost daily. Perhaps I should be flattered? Typically when I agree with another poster, I'll simply quote them and give it a x2, x100, Ditto... and then add any additional thoughts or information. More respectful to that poster, it doesn't appear as if I'm treating them like they are not there.M. Last edited by MyOtherRidesAVette; 06-09-2011 at 02:39 AM.. |
M. |
| Voltage drops | murph3699 | 2.0 Liter Gas | 9 | 05-12-2011 03:36 PM |
| Rough at idle, smell of gas, lack of power and weak top speed! | mistermcbrit | 2.0 Liter Gas | 3 | 09-26-2010 08:38 PM |
| HELP! Speed Buggy won't idle or run - he's mad at me! | silverspeedbuggy | 2.0 Liter Gas | 44 | 06-08-2007 12:25 AM |
| It just turned off..... | nyum96 | 1.8 Liter Turbo | 7 | 07-11-2006 11:20 PM |
