Showing Car: Hatch and doors open...drain power? all lights off? - NewBeetle.org Forums
Old 06-09-2011, 02:21 PM
BillyMagnum's Avatar
TDI Owner
LaVale, MD, USA
Car: 2000 NB TDI Red Flamin'
Default Showing Car: Hatch and doors open...drain power? all lights off?
So I'm debating on showing my car coming up in a few weeks.
It's nothing perfect but that's not the point. Anywho...
It has custom paintwork and subs in the trunk. I'd like to possibly leave the doors open slightly and trunk up to show it off. I know I can obviously switch the mirror and other interior lights off to keep from using power and burning up, but what about the trunk light?? is there any way to keep it off? Also is there anything else that will drain power? I'm not going to have the car on or anything but just want it open and everything off so I don't drain power.
Thanks
David
Old 06-09-2011, 02:46 PM
You could always unhook the battery if you are worried about draining it.
Old 06-09-2011, 02:54 PM
TDI Owner
LaVale, MD, USA
that never crossed my mind haha...good idea. anyone else have anything?
Old 06-09-2011, 02:59 PM
Not sure if there is a way to turn off those lights. Maybe a relay or fuse you could pull? I don't think those lights draw a ton of power though. So if its just a fairly short period of time you might be ok as long as you have a good battery.
Old 06-09-2011, 03:19 PM
MyOtherRidesAVette's Avatar
I'm not sure you can turn the cabin lights off. And I would not disconnect the battery, I'd simply pull the convenience lights fuse. The trunk light is probably on the same circuit, but, if not, pull that fuse also, or remove the bulb. Even that single trunk light could pull down your battery (especially age and condition related), over several hours. Have a good show!
MORAV
In der Automobil-Scheune
Old 06-09-2011, 03:22 PM
TDI Owner
LaVale, MD, USA
to the bently manual! to look at fuses lol
Old 06-09-2011, 03:27 PM
Car: 2001 GLX 1.8 Turbo - TechnoBlue
On my 2001 the interior lights turn off automagically after 15 ? minutes.
I have left my hatch and doors open over night on many occasions, and have never had an issue with the battery for the brief time they stay on.
Give it a try !
Old 06-09-2011, 03:54 PM
Question
I thought they might turn off automatically, but let the '00 OM get away without making a copy, and have learned to never assume what feature existed in one year on a NB existed in another. And you are right, the hatch light probably won't drain the battery over a few hours.
M.
Old 06-10-2011, 01:55 PM
Tesla's Avatar
Y2K Speedle
Car: 2000 Beetle 2.0 Manual
No need to worry. Just take your bug to the show and open everything. The bug will survive the day and will love you for that. If you want to stay on the safe side, bring your jumper cable and someone will be happy to help you at the show if something goes wrong.
Have fun!
Go out and ride
SPEEDLE
Old 06-10-2011, 02:02 PM
FastAndFurious's Avatar
Same Name, New Parts
Staten Island, NY, USA
Car: 99 BMP 1.8BT on air
unless your battery is very weak, it should be able to hold. If your worried about it, you could always just turn on the car for 5 mins or so and let it run every hour
Old 06-10-2011, 02:03 PM
Blugg's Avatar
Alaska, United Kingdom
Car: 1.9 TDi Alaskan Green
Lights will turn off automatically
In my Show Bug i have had both doors, bonnet and boot open for 3 days. It never moved from where it was being shown. When i came to start it there was no problem.
Old 06-11-2011, 07:15 AM
mltRegistered Member mlt is offline
St. Paul, MN, USA
Car: 2002 GLS 2.0L auto
If you are not planning to close/open trunk and doors you can always close all latches with a screwdriver and thus turn corresponding lights off. Just make sure no one will try to close trunk/door in such state
Old 06-11-2011, 02:08 PM
sublow1's Avatar
2 BAD BEETLES
Baghdad, Iraq
Car: 1999 beetle 2001 beetle
Talking Keep it all open
Take it from me I have been showing my bug for a little while now. I can leave my doors engine compartment and my trunk open all day and never have to worry about my battery going dead. It is very important when you're showing your car that you have everything open if not they will deduct points from you for everything they cannot see. Just a few pointers make sure that you have a good display with your car. Maybe a couple tools out an oil can a gas can a first aid kit this all helps with the judges. The more you can give them the more that they like. Good luck in car shows if you're down in Oklahoma maybe we can trade hints. GOOD LUCK.
Old 06-14-2011, 05:09 PM
TDI Owner
LaVale, MD, USA
thanks for the pointers everyone!
Old 06-15-2011, 07:17 PM
Motown Philly's Avatar
New Member Revisited
Detroit, MI, USA
Car: 2004 NB Convt 1.8T
Has anyone installed a Battery Kill Switch?
I've looked at them a couple times, at the Auto Parts store, but I was thinking it would be to much of a hassle everytime I would use it. I figured I would have to reset the clock, which wouldn't be to bad, but then if my Radio went into lock-mode, and I would have to punch in the code, and reset all the channels, which then I would most likely never use it again.
Any thoughts?
Thanks,
Phil
Motown ~ 2004 Cyber Green NB. CONVT. 1.8T
APR Tuned / APR R1 / New South Performace / Silicone Boost / N75 / K&N / Samco TIP-Hose Kit / GPA / 20% Tint / Cactus
Mrs. Motown ~ 2005 Passat GLS 1.8T
APR Tuned / APR R1 / N75 / 35% Tint
Old 06-15-2011, 07:29 PM
Blugg's Avatar
Any thoughts?
Thanks,
Phil
A better alternative, is just work out what you want to kill and pull the fuse
Old 06-19-2011, 11:54 AM
sublow1's Avatar
2 BAD BEETLES
Baghdad, Iraq
Default Battery Brain
This is what I use. Battery Brain Battery Charge Protector You can set it so the hot wire from your ECM and raido backup keeps all the info alive. Hope this helps.
Old 06-19-2011, 12:00 PM
sublow1's Avatar
2 BAD BEETLES
Baghdad, Iraq
Default Sorry read this
Battery Brain Battery Charge ProtectorImagine yourself in your car, stuck in traffic. You turn off your engine to save on gas. Finally, the traffic light turns green. You turn the ignition key and hear the engine chug. Minutes later, the traffic is gone and your car is on the same spot?in the middle of the highway. You later find out it's all because of battery failure. Avoid such an irksome scenario. Get a Battery Brain Battery Charge Protector. A battery charge protector is an add-on electric device that keeps your battery charged. If you want the best on the market, then buy a Battery Brain Battery Charge Protector. It's easy to install and connect to your car battery terminals. With this device, you can use your car lights and radio even if the engine is off; you need not worry about draining all the battery power. The Battery Brain Battery Charge Protector ensures that there will always be enough battery charge to start your vehicle. When it comes to battery add-ons, you should know what works and what doesn't. But you don't need to think twice with the Battery Brain Battery Charge Protector.
HELP!!!! Doors wont open from inside or out! Black_beetle_Martha Questions, Issues, Concerns, or Problems with the New Beetle 23 06-23-2011 09:38 AM
2002 Beetle doors wont open vauler Questions, Issues, Concerns, or Problems with the New Beetle 4 05-30-2011 07:04 PM
Hatch won't stay open crazycatz Questions, Issues, Concerns, or Problems with the New Beetle 5 12-23-2008 07:51 PM
What makes the hatch latch stay open when you open it? J Tinsby Questions, Issues, Concerns, or Problems with the New Beetle 3 08-16-2008 04:13 PM
Rear hatch won't open? 75shot Questions, Issues, Concerns, or Problems with the New Beetle 7 07-19-2007 09:49 PM
