I have installed my own fog lights on my 09 NBC, but not from the ECS kit. What I installed is basically the same purchased separately. Remove the left and right grilles, install lights, but leave the new grilles out until job is completed. You will need to install the one wire to the light switch pin 8/NL. (I prefer to use the Euro light switch.) This wire goes to the fog lights. Voltage is already supplied to the light switch for fog operation. The relay is not needed. Getting the wire down to the fog light is the biggest job.
This is the simple way, that is, the fog lights will be ON during high beams. Factory install (the legal way) disables the fog lights with high beams on, thus the fog light relay. This is a more involved installation which I did using parts from a donor car. Hope this helps.
A person can do this themselves, but you kinda need to know what you are doing.
Tom
