Trailer light plug? How to attach wires? - NewBeetle.org Forums
Old 02-13-2006, 01:38 AM
Love Machine's Avatar
Atoooo Washhh!
Waveland, MS, USA
Car: 1998 Techno Blue New Beetle, 1/2 of 2001 newbeetle, 2002CoolWhite New Beetle, 1969volksrod, 1971ghia
Default Trailer light plug? How to attach wires?
Has anyone here put a trailer hitch on there bug? I need to know on how to put the plug on the car? Does the wires have to be cut or is there a plug for the attachment? Thank you for your help and any info on how to would be good as well. Thanks, Greg
Old 02-13-2006, 02:48 PM
member
Glendale, CA, USA
Car: 2001 GLX (AWV)
There are little plastic clamp-on wire taps that make it easy to add a trailer wiring. U-Haul has wiring kits with converters for sale. You'll probably have to hang the connector out of the trunk when towing.
juice
Old 02-13-2006, 08:07 PM
jimRegistered Member jim is offline
Old Dog
Moore, OK, USA
Car: 2003 GLS
I used a converter because of the fear of all those electronics. I powered the converter from the power plug in the trunk, driver's side. You'll still need to connect the light wires from your lights, but with a converter these will just be used to trigger the particular solenoid.
Doodle, 2000 Black GLX, Auto.
New MAF and glow plug harness DR.billZ 1.9 Liter TDI 2 02-13-2006 03:57 PM
CD Changer Trunk Plug skachic20 Car Audio 3 01-28-2006 11:32 AM
oil pan plug oldceltjohn 2.0 Liter Gas 1 01-19-2006 07:01 PM
Spark wires - Do I need to remove the manifold? [lot] 2.0 Liter Gas 17 11-21-2005 05:51 PM
Problems changing plug wires & fuel filter. jent 2.0 Liter Gas 8 10-10-2005 08:04 PM
