98 proportioning valve adjustment - NewBeetle.org Forums
Old 12-27-2011, 06:37 PM
Default 98 proportioning valve adjustment
Do you need to adjust if you raise or lower your car? The reason I ask is I raised my nb 3" and now the rear brakes don't work.
Thanks
Old 01-15-2012, 09:25 PM
TDI_bubble's Avatar
Yes, you will need to adjust the throw on it. It works from the lever connected to the axle to gauge how far the car is nose diving/lifting rear wheels.
I would suggest adding/bending that bar to make up for how much you lifted it.
Old 01-16-2012, 02:08 PM
I tried using the adjusting lever with no success. Although I did'nt try bending or adding on for more adjustment. So I bypassed the valve completely and now I can get them to at least slide in the snow. Before they would'nt so I can stop much better, at least when It's slippery. Could it be with the larger and much heavier tires that the rear brakes are just to small to handle them?
Thanks
Old 01-22-2012, 05:03 PM
TDI_bubble's Avatar
Well the discs in the back are fairly small to begin with, what size tires are you running? I'm in the process of getting a lift together for mine as well. Trying to run 28s or 29.5's, don't know how bad the gearing will be with 31's and trimmed fenders?
Old 01-23-2012, 12:18 PM
Thumbs up
29's just fit with a 3" lift. I have no problem with power with the taller tires. In fact I pull my snowmobile with no problem!
Old 01-27-2012, 01:06 AM
TDI_bubble's Avatar
Any pics for the net?!
2.5L PCV valve, valve cover replacement questions PTL5spd 2.5 Liter Gas 2 09-03-2011 11:27 PM
Evap Purge Valve/N80 Valve BUGSTUFF 2.0 Liter Gas 6 03-17-2011 12:51 AM
Door Gap Adjustment grantsbeetle 2.0 Liter Gas 11 04-30-2010 03:28 PM
diverter valve/ blow off valve silver01beetle Miscellaneous Hoo-Ha Archive 3 06-20-2006 05:29 AM
combie valve & N112 valve (vacuum lines)??? marisagi 1.8 Liter Turbo 1 02-09-2006 11:53 AM
