hatch replacement question - NewBeetle.org Forums
Old 12-29-2011, 09:31 PM
lilu05's Avatar
Providence, RI, RI, USA
Car: 2003 VW Beetle 2.0L GL
Default hatch replacement question
Hi guys. My rear hatch was kicked in a while ago by my nasty neighbor. I went to the junkyard today and there were two beetles there that still had their hatches. Both of them had the hatch entry where you rotate the VW symbol and put the key in to open them. On my car I have automatic locks and the hatch pops open when I hit the button. Is there any way to replace my hatch with one of the ones from the junkyard while keeping my automatic locks or do I need to get another hatch with the same locking mechanism as the one I have? Thanks
Old 12-30-2011, 03:23 AM
The rotate and open still has automatic opening from the driver door and from the key fob. It just has a mechanical lock in case you need to get in and the electronics fail.
What I don't know is if that door is going to be compatible, it's from an older year and while many things don't change, some do.
Old 12-30-2011, 09:37 PM
LiftedBeetle's Avatar
ME, USA
The question is, what did you do to piss off your neighbor? lol
Rear hatch....quick question. Savage Henry New Member Forum 2 08-20-2011 04:08 AM
opening rear hatch question jerbacher Questions, Issues, Concerns, or Problems with the New Beetle 14 04-25-2011 10:57 AM
Tie Rod Assembly replacement question. BW505 Questions, Issues, Concerns, or Problems with the New Beetle 1 01-24-2011 03:19 AM
2000 NB - Trunk hatch release w/lock question ronin4740 Questions, Issues, Concerns, or Problems with the New Beetle 4 12-09-2009 07:07 PM
Question about the hatch door Black Cat Questions, Issues, Concerns, or Problems with the New Beetle 3 11-13-2006 06:09 AM
