wiper blades - NewBeetle.org Forums
Old 01-17-2012, 05:11 AM
Ft. Wayne, IN,
Car: 00 TDI NB
Default wiper blades
OK i've searched through the threads and come up with some good stuff, the problem is it appears to be outdated. Bosch Icon blades appear to not even be made for the beetle any more, even looking at bosch's site they do not even support those blades. I don't want to have to order online for the valeo blades so what are good blades out there currently that you can actually buy?
thanks
Old 01-17-2012, 12:16 PM
The NB has never been listed for the Icons as far as I'm aware. I looked for years for those. I ran the Bosch Microedge blades and was happy with them. Not sure, but Bosch has a cheaper version of the Icons that I'm running on my GTI. You can check those and see if they are listed for the NB.
Old 01-22-2012, 05:19 PM
LiftedBeetle's Avatar
ME, USA
I just bought and installed some bosch icons on my beetle. Every windshield wiper I have ever changed all mount the same, regardless of make or model, and I have easily changed out hundreds over the years. Just go to your local auto parts store and ask for one 21" blade (drivers side) and one 19" blade (passenger side). Like I said, I know bosch makes the icon blades in those sizes because I just bought them a week ago.
Old 01-22-2012, 05:48 PM
The size they make, but they don't list the NB in the application. I think it might have something to do with how the windshield curves.
Old 01-22-2012, 08:24 PM
ME, USA
I am telling you, the model of car makes NO difference. They will work on the beetle, as I have them on mine right now! They are much better in all weather conditions (snow, ice, rain) than the stock type that were on there before.
Old 01-22-2012, 08:52 PM
doublebarrel's Avatar
Irving, TX, USA
Car: 2000 gls tdi
I put some Michelin Stealth wiper blades on mine a couple of months ago and I'm real happy with them.Got them at Walmart when I was on vacation and my Bosch were getting bad.
Old 01-22-2012, 09:48 PM
I'm not saying they won't work, but if you look in the book or online, the NB is NOT listed for Icons. That much is true. I never ran them. Used the Microedges and they worked great and were much, much cheaper. I have a cheaper version of Icons on my GTI and they work well too. Also made by Bosch. Can't really figure out a difference between them and the Icons.
Old 01-22-2012, 11:46 PM
boogety boogety's Avatar
Boogety Boogety
Dallas!, TX, USA
Car: 2006 NBC
I have Icons on my NBC... as well as on all our other cars that have needed blades in their term of service. Best replacement blades out there, bar none, and I've tried a bunch of them over the years.
Icons come in sizes (for example, "21" for 21") followed by a letter designation: "A" and "B". "A" wipers are for regular windshields, and "B" are for greater curvature in swept area. The "Bs," in other words, have a more aggressive arc on the frame. Should you use them in flatter areas, you might have a problem with them lifting in the center of the blade during their sweep. So, a 21A and a 19B will take care of your New Beetle.
So: For cars with the windshield wipers that rise towards the driver's side, get the "A" for the driver's side, and the "B" for the passenger side, and the reverse if your vehicle has windshield wipers that rise towards the passenger side.
Old 01-23-2012, 12:15 AM
IndyTom's Avatar
Indianapolis, IN, USA
Why the shorter blade for the passenger side? The listing for the 2000 NB calls for 21inch blades for both driver and passenger sides??
Old 01-23-2012, 01:44 AM
ME, USA
Idk. The parts jockey at the local Car Quest said that's what it called for. I know Sunfires and Cavaliers have smaller blades on the passenger side and I'm sure I've seen it that way on other cars as well. Not sure about the reason behind it.
Old 01-23-2012, 02:09 AM
CoriBug's Avatar
over 120k miles in 7.5yrs
Fort Collins, CO, USA
I used Bosch Icon wipers for a year or so...the stock VW are just as good IMO.
Old 01-23-2012, 09:24 PM
I know we had a discussion somewhere here and a fellow was asking about sizes. I suggested a 20/20 fit because of the poor outer edge performance on some wiper blades. Primarily the passenger side, and a smaller blade held down better.
The A/B version sounds pretty spiffy, likely not something you'll see on the brands at walmart.
19 does sound small, and 21 definitely fits as that is what your car would have come with.
21 A for the driver, 21 B for the passenger side, everyone is happy?
Old 01-24-2012, 07:40 AM
Ft. Wayne, IN,
Car: 00 TDI NB
well i didn't wait long enough to see that the icon's would just work so i decided to try the trico teflon because they had a little air foil to help hold them down on the winshield. waste of money stay away from these if you are looking for new blades. I wasted my cash i dont want to see anyone else make that mistake. I'll be replacing them soon with the bosche icons.
thanks for the input guys
Old 01-24-2012, 01:38 PM
texvw's Avatar
Bug Lover
dallas, TX,
Car: 2000 1.8t gls silver arrow
I purchased a set of Icons a few wks ago. Finally got around to the install over weekend. I purchased 21E, not knowing that there was a difference in the blades. We played with installing these blades for an hour, checked out the Bosch site, a few others. These blades will not work on a NB. (If anyone has ever installed the E blade on their NB, please show me how it's done.)
So, installed a cheapy set of Michelins over weekend. Supposed to rain for next 3 days so we'll see how they do.
vicki
Romboli - 2000 1.8t GLS silver NB
http://newbeetle.org/forums/photos-n...-1-8t-gls.html
Old 01-24-2012, 02:37 PM
IndyTom's Avatar
vicki
Never heard of the Icon E blade before?? I knew they have A and B but E??
Old 01-24-2012, 03:25 PM
I don't remember what exactly the label was on them, but I did buy a set of Icons to try on my NB once and the hook system was entirely different and would not go on the car. Returned them and just got the Microedges again. No issues there ever.
Old 01-24-2012, 03:28 PM
IndyTom's Avatar
We have standard hooks on our wiper arms so they will work fine with the Bosch Icons. I haven't tried them yet but I guess I might just have to now
Standard on my wiper arms, but not on the actual wipers I bought. It was really, really strange.
Old 01-24-2012, 03:29 PM
nitroman's Avatar
Vancouver, BC, Canada
Car: 1999 GLS 2.0 Auto 120,000 kms
Anyone every tried the Bosch Excel+ blades? It supposedly has the same "fx dual rubber technology" as the Icons, it's just not a blade style but the old spring style.
So far for me in Canada I haven't found any decent prices on the Icon, only at a local store which is like super expensive, but I was able to find some Excel+ for a good price.
Old 01-24-2012, 04:18 PM
I can never remember what mine are but I think I'm running those on my GTI and they work fine. I know they are Bosch and the cheaper version of the Icon. Don't really notice any difference and the cost is much more reasonable. Hubby bought them for me and I know I've asked him 20 times which they are but I can never remember
noisy wiper blades deenalouise New Beetle Convertible 7 05-19-2011 05:05 AM
WANTED: Wiper Blades BUGSTUFF Parts and Accessories 9 11-13-2010 08:39 PM
New Beetle 2001 Wiper Blades Bradsr51 New Member Forum 1 01-05-2009 01:20 PM
Winter wiper blades dunno513 Questions, Issues, Concerns, or Problems with the New Beetle 5 12-13-2006 08:28 PM
Replacement wiper blades 2004 smokey 2.0 Liter Gas 11 09-30-2005 08:57 PM
