Eibach Pro System Kit Install - NewBeetle.org Forums
Old 02-02-2012, 07:07 PM
RedDragon's Avatar
TDIer
Millbrook, IL, IL, USA
Car: '01 NB TDI "Red Dragon"
Default Eibach Pro System Kit Install
I'm getting the Eibach Pro System Kit installed on my NB, since the suspension is 12 years old and the upper strut bearings. The shop that im probably going to have do most if not all my installs. Anyway the kit is ~$570, then he said the install would run $405. I dont know much about installing suspension, but id just like to know if $400 is reasonable or not.
Thanks for the help.
'01 NB TDI 165k 4-spd Auto-Mufflerectomy,Catectomy,DieselGeek Race Pipe,Evry Mod,Neuspeed P-Flo,TDI Badge,18" Audi A8 Reps w/ 225/40-18 Kumho AST's,6k HID's,Tinted Tail Lights,Custom Dual Exhaust,25mm H&R Rear Sway Bar,Eibach Pro System
Old 02-02-2012, 07:38 PM
IndyTom's Avatar
Indianapolis, IN, USA
Are you replaceing the struts and shocks along with the springs? I used to have the Eibach Pro Kit on my Audi TT and it was great along with my Koni struts and shocks. The stock struts won't be able to handle lowering springs for very long. Also an alignment will be necessary after the install. $400 is a bit steep for installation of Springs. A shop can easily do that in about 2 hours in all four corners. I personally would do it yourself and safe the money. It may take you a little longer without a lift and some powertools but it can be done. I would check around. I think 250-300 would be a fair labor price for shocks/struts and springs.
Old 02-02-2012, 08:01 PM
RedDragon's Avatar
TDIer
This is the kit that is being installed:
Eibach Pro-System Kit
It has everything right?
Old 02-02-2012, 08:05 PM
IndyTom's Avatar
Sorry that link doesn't bring up the Eibach kit. Just a bunch of listings for all sorts of stuff.
I cut and pasted the link instead and it did bring up the Tire Rack link.
Yup, that looks good. Springs and all.
Old 02-02-2012, 08:34 PM
RedDragon's Avatar
TDIer
So is $400 still kind a steep?
Old 02-03-2012, 03:39 AM
IndyTom's Avatar
I think so. Unless it includes an alignment which you will definitely need.
Old 02-03-2012, 12:42 PM
Car: 2001 GLX 1.8 Turbo - TechnoBlue
One of the reasons most places charge more for our strut changes is the extra effort required to do the Front drivers side. You either undo the cv joint, or you loosen the subframe to get the extra space need to get it out.
It's not that hard for a competent shop, but it does add time to the process.
If they've actually done good work on your car before- I feel its worth any extra bump just for the security that provides.
Hard to find a good shop- I like to reward those that are.
Old 02-03-2012, 02:40 PM
RedDragon's Avatar
TDIer
ya it does.
Thats very true the last part.
Opelmania's Avatar
Dubbed Spiderman
Woodstock, IL, USA
Car: 98 2.0 5 Speed
Nice to see RedDragon getting an upgrade! Can't wait to see how it looks after.
RedDragon's Avatar
TDIer
Thanks for all the good input guys
Old 02-03-2012, 02:42 PM
RedDragon's Avatar
TDIer
All for ToD!!!!
system install TodayIsOnMyMindx Car Audio 3 09-13-2008 09:16 PM
System install with pics PLAN_B Car Audio 17 08-07-2008 02:28 AM
WTB Eibach Pro System Kit stilrunin Market Place Archives 0 01-29-2006 03:17 PM
