How to prevent auto door locks from locking? - NewBeetle.org Forums
Old 03-20-2006, 03:46 AM
Default How to prevent auto door locks from locking?
I figured out why daughter bug was going dead?
Problem is the remote door lock. For some reason it will drain the battery when doors locked with the remote. Daughter went to spring break for a week. The doors were unlocked when she left. Came back bug started..
After starting bug went in dorm and came back
doors were locked for 3 hrs and Bug was dead.
She did not lock them.
How do you prevent the doors from automatic locking even if you don't lock with remote. What is the scoop on that?
Is there a fuse to pull or what.
Thanking you in advance.
Old 03-20-2006, 05:49 PM
JDigga's Avatar
Driver
Cleveland, OH, USA
Car: 2009 Toyota Tacoma
There are two instances in which the doors will lock themselves automatically:
1) when you unlock them but don't open any of the doors or trunk for 30 seconds--the car relocks itself.
2) after starting and going over 10mph (if enabled by the dealer or by someone with a VAG-COM.
Maybe she left the lights on? And what is she doing leaving her doors unlocked for a week while she goes to spring break?!?
2009 Toyota Tacoma
1987 Porsche 911 Carrera
1987 BMW 325i Convertible
Old 03-26-2006, 02:07 AM
I wanted to verfiy that this is was the problem.
I was hoping that some one would steal it.
Was not that lucky. She got home after a week and it stated. I know now for SURE what the problem was
Old 03-26-2006, 03:11 PM
Porkchop's Avatar
a.k.a. porkchopzz4
Cartersville, GA, USA
Car: '00 Silver GLS 2.0L auto
There should be a way using the VAG-COM to turn off the auto locking. I say this because I know you can stop the horn chirp when you lock them and you can make both doors unlock at the same time by changing the values with the VAG-COM.
"The rich ruleth over the poor, and the borrower is servant to the lender."
Proverbs 22:7
Old 03-26-2006, 03:23 PM
pdoel's Avatar
Pittsburgh, PA, USA
Car: 2000 Cyber Green, 1.8t
Well, I don't think the doors being locked or unlocked would actually drain the battery. It would actually be the alarm system being set that is draining it.
I have heard of the alarm being able to drain the battery if the car sits for an extended period of time. However, three hours, or even a week, shouldn't be long enough to drain the battery.
Any other info? What year is the car? Is this the original battery? Anything added?
I do believe there were issues with the early satellite radio equipped Beetles where the radio would drain the battery as well.
Cyber Green. It's not a color. It's a way of life.
'00 GLX Cyber Green / Cream, 5sp. (Click for pics!)
'07 Audi A3 S-Line
Old 07-02-2006, 02:33 AM
ghostRder1's Avatar
GA,
Car: 2006 Convertible
Thanks for this answer. Mine was locking itself and lol i had no idea why until i read your answer. I know now why the doors were locking themselves.
This org is so helpful to so many of us.
How to prevent auto door locks from locking? fatdaddy Questions, Issues, Concerns, or Problems with the New Beetle 4 03-22-2006 05:14 AM
Door Locks Muffed Up???? 1poorvw 2.0 Liter Gas 4 03-14-2006 02:22 AM
Which fuse is for the auto door Locks? fatdaddy Questions, Issues, Concerns, or Problems with the New Beetle 1 03-11-2006 01:32 PM
Window regulator and Door Locks burn out ACEKQJTEN Questions, Issues, Concerns, or Problems with the New Beetle 2 03-10-2006 11:10 AM
Door Locks Buglover Technical Modifications 1 10-12-2005 11:48 PM
