Never mind. I figured it out. That thing is a pain in the a$$. You have to pull the top of the dash off and then the cover for the ECM. Then under that is an access panel you remove to get to it. That is actually the turn signal I guess that I was talking about. The part number for it is 1c0949101b
Just finished swapping out my passenger side LED turn signal under the mirror. Intended on taking more photos as I put it back together, but ran out of sunlight due to a bit of a snag.
![]() Here's a tip: Before you go to the effort of removing the LED, place a voltmeter in the connector of the turn signal and check for voltage. That way, you don't unnecessarily remove a good LED!!!! ![]() ![]() Turns out the wire harness behind the cabin filter was severed. I can only think it was some type of rodent that got in there and chewed. ...or maybe some copper thieves! ![]() If yours is bad, the process is just like replacing your cabin filter with these additional steps: 1. Remove cabin filter housing by removing the 2 plastic 10mm nuts on either side AFTER placing a large rag in the hole of the housing. Don't want any of your tools or nuts falling down there. 2. Pry the gray plug (comes out just like a weather grommet) 3. Depress locking tab on the right side of the connector outward and gently wiggle and pull the connector out (I kept trying to pinch the tab until I looked at it closely) ![]() My replacement LED had phillips screws, but my original had torx. Getting the thing out is a trail of patience in that you can't just slide it out. |
| WTB: Red rear marker lights (Pass. side or pair) | NYBugman | Market Place Archives | 7 | 03-13-2006 06:28 PM |
| Where To Buy Side Marker Lights ( Under Mirrors)??? | 1FSTBUGG | Styling Modifications | 2 | 01-03-2006 03:40 PM |
| Rear Marker/Brake Light | abitbent | Questions, Issues, Concerns, or Problems with the New Beetle | 4 | 11-14-2005 01:00 PM |
| No side marker lights! | Turboboy | 1.8 Liter Turbo | 6 | 10-25-2005 07:52 PM |
| WTB: clear fog light lens covers - clear | callisto9 | Market Place Archives | 1 | 10-21-2005 03:13 PM |
