Tiptronic shift knob removal - NewBeetle.org Forums
Go Back   NewBeetle.org Home > NewBeetle.org Forums > 1998-2011 New Beetle > Modifications > Technical Modifications
Old 04-30-2006, 02:03 PM
hestersu's Avatar
Canyon, TX, USA
Default Tiptronic shift knob removal
Has anyone done this and if so, are you willing to write a how-to?
Susan Hester
Former owner of:
Old 05-01-2006, 05:09 AM
NYBugman's Avatar
MkV Pilot
Brooklyn, NY,
Car: 08 CW GTI Pkg1 DSG
If it's anything like for the 4-speed auto, the it's easy.
Turn car on and shift into neutral.
Turn car off and engage parking brake.
Pull the collar of the shifter down
Push button in and pull
Done
Old 07-11-2008, 12:29 PM
tvs tvs is offline
Default How-too Tiptronic **** knob removal and installing
[B]Removing
-Place selector leer in position "P"
-Slide sleeve -1- downward.
-Pull button -2- out of handle -4- until it stops - arrow-.
-Secure button from springing back eg. using a wire bracket -3-.
-Remove selector handle,up.
Installing
-Place selector lever in position "P".
-Pull button -2- out of handle -4- until it stops -arrow-.
-Installation position :Switch faces driver.
-Press handle onto selector lever up to stop.
-Remove wire bracket.
-Press button -2- in order to secure it.Button must now spring back to stop again.
-Rotate and slide sleev -1- upward until tabs in sleeve engage and lock audibly into slots of handle -4-.
Old 07-11-2008, 12:33 PM
tvs tvs is offline
Default Tiptronic shift knob removal and installing
Foto
Selector lever handle, removing and instaling
Old 03-05-2009, 06:38 PM
Cool Yay!!
Originally Posted by tvs View Post
[B]Removing
Installing
You saved me a quoted $175.95CDN in Shop Fees (estimated by a volkswagen dealer in town) with this info. You see, my Shift Knob shattered (really) due to extreme temps (-45Celcius) and clumsy shifting. So I ordered the stock replacement, and was quoted $175.95CDN to install. I'm thinking, no friggen way.
Followed your directions.
Installed, works.
Thanks man! How can I repay?
(Yes, it's out of warranty)
Old 03-05-2009, 07:55 PM
bigsexyTDI's Avatar
Diesel Freak
Paducah, KY, USA
Car: '98 TDI
Unfortunately none of this helps Sue since she has a DSG...
SMAUG - '98 UNI-RED NB TDI, UPSOLUTE, SPRINT 205's, EIBACHS, BILSTEIN HDs, CAT & MUFFLERECTOMY, .:R32 ARISTOS, GENERAL EXCLAIM UHPS, 250K AND CLIMBING
Old 03-05-2009, 08:00 PM
Fl_bug's Avatar
Catch me riding s00ty!
Miami, FL, USA
Car: Formally 2001.5 Sport 5speed-- Titan Currently 2005.5 Jetta TDI
Especially since the question was asked on "04-30-2006, 10:03 AM"
But I'm sure the handle should come off about the same.
Old 03-05-2009, 08:15 PM
bigsexyTDI's Avatar
Diesel Freak
Paducah, KY, USA
Car: '98 TDI
damn... didn't notice that...
I always just hit "new posts" when I log on, and just assume they are current, and that someone hasn't bumped up a three year old thread
Old 03-06-2009, 01:21 AM
hestersu's Avatar
Canyon, TX, USA
Actually, the DSG has a version of the Tiptronic and the above instructions worked for me as well.
Glad it worked for someone else.
Old 03-06-2009, 02:18 PM
Wheaton, IL,
Car: 04 TDI PD
I have a DSG and the instructions are the same.
Be careful not to use too much force when pulling the button out of the handle as the button can come completely out.
If you pull the button completely out you can't simply push it back in as there is a spring-loaded lever that needs to be pushed up out of the way. Best way to get at the spring-loaded lever is to remove the T-handle from the shifter post.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
Shift Knob diameter? kcfoxie Styling Modifications 7 11-27-2008 09:30 AM
Auto Shift knob and E-Brake GaUdeNtiUs Styling Modifications 23 10-14-2008 07:04 PM
For Sale: NB OEM Shift knob FineExampl Market Place Archives 2 03-16-2006 11:25 PM
Please help me! Installing a new aluminum shift knob symphonik Styling Modifications 1 11-17-2005 01:55 PM
How to install alminum shift knob? symphonik Styling Modifications 0 11-12-2005 08:12 PM
