Audi TT brake rotors - NewBeetle.org Forums
Old 05-05-2006, 02:58 PM
WNAB911's Avatar
Dix Hills, Suffolk, USA
Car: 1998 New Beetle "Bee Hive"
Default Audi TT brake rotors
I am getting conflicting advice on this. Will Audit TT brake rotors bolt on to my 1998 2.slow???? I am getting some new rims and want to cheaply do a bigger brake behind them.
Old 05-05-2006, 03:59 PM
bugasm99's Avatar
OG Stalker
Philadelphia, PA, USA
You can bolt the rotors on, but you need a larger caliper carrier to push the caliper farther out to clear the rotor. a lot of tuning companies carry complete kits with new rotors, caliper carriers, bolts, etc for a decent price.
Old 05-07-2006, 07:27 PM
Pittbug's Avatar
The Flying Englishman
Columbus, OH, USA
Car: APR Stage III Beetle
iirc the 2.0 caliper bolts directly onto the knuckle, it doesn't have a carrier like the 1.8 version... I don't think it'll work for you.
My 2001 APR Stage III Beetle
Old 05-07-2006, 08:18 PM
bugasm99's Avatar
OG Stalker
i appologize. I skipped right over the 2.0 part. You would need to get a spindle from a 1.8t or vr6 in order to do the TT kit.
Old 05-08-2006, 02:28 AM
Pelican18TQA4's Avatar
CRAZ4VW
Hatboro, PA, USA
Car: '08 BMW 128i coupe
Trust me, it's a worthwhile upgrade
'10 GTI 2-door | '08 BMW 128i coupe | '07 GTI 4-door | '02 Golf GL TDI
Old 05-09-2006, 03:12 PM
Too Cold NB1.8T's Avatar
Keep It Real
California, USA
If you have a 2.0L then you then I don't believe it would be a direct bolt on, some parts would have to be changed.
The 2.0L doesn't have much juice under the hood and I realize that what I'm about to say is subjective, however, I have to say that this isn't a cost effective worth while upgrade unless you've added a super charger or something.
You might want to consider changing to better than stock quality "slotted" rotors on all four corners and replacing the stock pads with Ultimate Axxis brake pads, this would lend a nice look and a significant performance improvement over the stock setup without the unnecessary time and expense of what would be required for a big brake upgrade.
Drilled rotors Lnzbug Technical Modifications 8 04-08-2006 05:37 PM
If I don't machine my rotors.... jesse 1.8 Liter Turbo 9 03-31-2006 08:03 AM
Brake pad/rotors replacment in Calgary? Lunar2002 The Canada Corner 3 03-09-2006 01:30 PM
Best Brake Rotors? afroehle 1.8 Liter Turbo 3 01-30-2006 06:53 PM
Rear rotors Billsbug Styling Modifications 6 01-05-2006 11:29 PM
