Diverter vs. bypass - NewBeetle.org Forums
Old 05-08-2006, 02:11 AM
Default Diverter vs. bypass
I have a 02 turbo s and I was wondering the difference between blow-off valves and diverter valves. I heard blow off valves can cause check engine lights.
Old 05-08-2006, 03:00 AM
NYBugman's Avatar
MkV Pilot
Brooklyn, NY,
Car: 08 CW GTI Pkg1 DSG
A blow-off valve (BOV) vents air into the atmosphere. Diverter Valves (DV) vents the excess air back into the air intake. The computer wants to see that air recirculate into the flow. If it doesn't, then it thinks the car is running rich/broken and it throws a CEL. This doesn't happen all the time, but it happens more often than not.
If you want sound, then remove your airbox and install a K&N cone filter/short ram and you'll hear all the wooshing you want.
New Diverter Valve, Thanks! Oyveychris 1.8 Liter Turbo 20 05-22-2007 11:11 PM
what blow off/bypass valve should i get? Flash237 1.8 Liter Turbo 10 03-04-2006 02:31 PM
replaced diverter valve beetlejuice 1.8 Liter Turbo 4 03-01-2006 01:47 AM
shimming a diverter valve GENETIX RACING Technical Modifications 3 12-12-2005 04:06 PM
Diverter valves GENETIX RACING Technical Modifications 3 10-23-2005 04:13 PM
