how much does the stock 16 alloy rim weight? - NewBeetle.org Forums
Old 05-09-2006, 04:17 AM
richmond, B.C, Canada
Car: 2001 beetle 2.0
Default how much does the stock 16 alloy rim weight?
Old 05-09-2006, 02:37 PM
Too Cold NB1.8T's Avatar
Keep It Real
California, USA
As I recall, the stock 16" wheel/tire combo weighed in at 46Lbs. but this could change depending on which brand tires the car came with.
Old 05-09-2006, 02:42 PM
SPIRU's Avatar
RESPECT MY AUTHORITAH!
Naples, FL, USA
Car: Black Rain - 2K1.5 Black GL
good question, but what about the steelies?
Tríd an bpian a bheirtear solas nua!
Most of us spend our lives as if we had another one in the bank - Ben Irwin
Live Strong / Black Rain my NB! / Love Da Scot / My flickr / My Tattoo / MySpace / My XBL GamerTag
Old 05-09-2006, 10:43 PM
that is heavy
Old 05-10-2006, 12:33 AM
Keep It Real
California, USA
The tire alone could weigh in the area of 22Lbs. to about 26Lbs., subtract this amount from the 46Lb. combo weight and you'll find that the stock 16" alloy wheel is a reasonable weight and not very heavy, especially for an OEM part.
Old 05-10-2006, 03:09 AM
i thought only the rim are heavy but not the tire
so dumb
Old 05-10-2006, 02:07 PM
Keep It Real
California, USA
I alway try to consider peripheral effects prior to performing modifications/upgrades on a car, unfortunately too many people only look at part of the picture and end up with less than satisfactory results.
In many cases a tire will weigh as much or more than the wheel it will be mounted on, it's very important to get in the habbit of looking at the entire picture in these matters
For instance, when I went from a Bridgestone SO3 Pole position 225/40ZR 18's (28Lbs.) to a Goodyear F1 225/40YR 18's (24Lbs.) on the same wheels, I dropped 4Lbs. of tire weight per corner totaling 16Lbs. of unsprung weight removed just in tire weight....
Diet / Weight Loss Methods? dnyed Miscellaneous Hoo-Ha Archive 536 06-05-2008 01:25 AM
Rim help dkarmann Styling Modifications 24 03-31-2006 07:58 PM
Weight Reduction newbeetlecup Technical Modifications 15 03-01-2006 02:39 AM
Weight of Stock 16x6.5 BBS alloy? sb_beetle Technical Modifications 0 11-15-2005 10:21 PM
Hooray for weight loss! FineExampl Miscellaneous Hoo-Ha Archive 20 10-25-2005 08:23 AM
