R32 Steering Wheel - NewBeetle.org Forums
Old 05-17-2006, 06:42 AM
Default R32 Steering Wheel
hi there,
Anyone installed a R32 Steering wheel on a Beetle? I see that HPA has a R32 wheel in their Beetle.
I have the follow Q's
1) Is it a direct bolt on?
2) Is the airbage plug and play?
3) Any airbag light?
thanks in advance
1pt8t
Old 05-17-2006, 04:51 PM
bugasm99's Avatar
OG Stalker
Philadelphia, PA, USA
1) yes it will bolt right on as long as you are using the r32 airbag with the r32 wheel.
2) I am unsure but I have seen R32 wheels in a beetle so it is possible.
3) as long as the airbag is connected properly you should have no airbag light.
Old 05-20-2006, 01:13 AM
Too Cold NB1.8T's Avatar
Keep It Real
California, USA
Originally Posted by 1pt8t
hi there,
Anyone installed a R32 Steering wheel on a Beetle? I see that HPA has a R32 wheel in their Beetle.thanks in advance
1pt8t
I have the follow Q's 1) Is it a direct bolt on?
Yes, the R1 steering wheel (VW part #JNV 419 091)is a direct bolt on for the Beetle.
The airbag doesn't have to be an R32 airbag, any "Three Spoke Sport" airbag for/from a Jetta, Golf etc. will work with the R1 wheel and be plug and play on a Beetle.
No airbag light or fault codes should result if the airbag removal and installation procedures are strictly adhered to and as long as the airbag used is in proper working order and un damaged.
Old 05-23-2006, 01:53 AM
Just make sure to disconnect your battery before doing the wheel swap.
PS You're gonna love it!
Old 05-23-2006, 02:30 PM
Keep It Real
California, USA
As stated in my previous post, the airbag removal and installation procedure should be strictly adhered to, one of the first things stipulated in that procedure is to disconnect the battery prior to working on the airbag system.
If you carefully follow the Bentley service manual during this procedure, you should have no problems.
Enjoy!
Old 05-24-2006, 06:40 AM
thanks for the help guys. I am still waiting for my manual from Amazon. Also looking for the wheel as well right now.
1pt8t
Old 05-24-2006, 12:05 PM
Bef's Avatar
BefNewBeetle.org Member Sponsor Bef is offline
Cleveland, OH,
Car: 2012 Launch Edition
Good luck finding one!! They're not easy to come by, and they're pretty expensive. Oh, how I would love to have one as well...
Old 05-24-2006, 01:17 PM
Keep It Real
California, USA
It's true that the R-Line wheel (FYI: Comes with connection harness) is a little costly but they are extremely nice wheels and not at all hard to find, I supplied the part number in my first response to this thread, with that you should be able to locate one through any VW dealer, Driver Gear dealer or on line at World Impex.
The real expense and difficulty might be in finding a "Three Spoke Sport Airbag" in mint condition without having to buy one new from a VW dealer at a cost of about $800 plus, you have to be very careful when buying one used because they often come all scratched up and/or damaged.
I was fortunate to get mine for under $300 off Ebay from a local seller and was able to pick it up in person and inspect it, the airbag was off a low mileage car, came with the harness and was in new like condition.
Good Luck.
Old 05-24-2006, 04:16 PM
JuggBug's Avatar
CC + JB = TRUE LOVE
PIEHOLE, USA
Car: World Famous JuggBug ~ 2006 Harvest Moon
Tim has an Rline wheel....there's a pic on his thread....IT'S HOT!!
heezabadboy's Aquarius blue 2006 NBC GLX
TOTALLY SPOILED. BUT TOTALLY WORTH IT.
Old 05-24-2006, 10:00 PM
heezabadboy's Avatar
flyin hawaiian-
san antonio, TX, USA
Car: 2006 convertible glx
Talking hang on fellas
it depends on what year this guys bug is as to how easy the airbag swap is gonna be...mine is an 06 and it WASNT a plug and play....
HEEZABADBOY
Old 05-24-2006, 11:22 PM
trainspotted2's Avatar
Retro-a-go-go
Fort Worth, TX, USA
Car: 2001 1.8T GLX
I have an R32 steerign wheel swapped into my 2001 NB. It was all plug and play as long as you get a 3-spoke airbag with the wheel. I found mine on VW Vortex for a decent price as somebody was gutting an R32 into a racing project and had the wheel up for sale.
The hardest part of the install was removing my stock steering wheel. No matter how hard we tried, neither my friend (VW tech) or I could get enough leverage on the spring clamps that hold the steering wheel to the steering column to get them to budge and release the stock wheel. After a couple hours of trying we gave up and cut the sides out of the stock wheel so we had direct access to the spring clamps and were able to release them. Once released, and with the stock wheel removed, the R32 wheel installed in seconds. Of course, since this trashed the boot at the back of the stock wheel, the mod is irreversible. Hopefuly your stock wheel will be much easier to remove. I've seen it done in minutes but for some reason mine was very stubborn.
Old 12-16-2009, 10:37 PM
Default R-line steering wheel R32
from what i understand these steering wheels parts # JNV-419-091 can fit on pretty much any vw 3 spoke based steering wheel system. i got an 06 jetta tdi manual and i want to put in this steering wheel cuz it look good and feels good! vs the crappy cheap plastic stock steering wheel that might cause you eczema pr skin infections lol. does anyone have experience and confirm the fitment of this part on a jetta? any place cheap i can get one? also im thinking about putting in the 5 speed shifter knob from the r32 i think its art # JNV-711-113-D which may also fit in my car any suggestions would be greatly appreciated.
Old 12-16-2009, 11:48 PM
noR's Avatar
Administrator
Jackson, MS, USA
Please ask your question in a new thread Maroc.
Your question seems loosely related to the original, but the OPs question has already been answered... over 3 years ago.
Rather than revive a 3yr old thread, please start another which relates to your problem specifically.
noR | me | Phrog
PHROG
Old 12-17-2009, 07:36 AM
Deserion's Avatar
Moddin' Lion
Jacksonville, FL, USA
Car: '95 E320, '04 986
Maroc: You'll need the steering wheel from a Mk5 GTI or R32 (same thing except for the aluminum filler plate) to put on your Jetta. The Mk4 wheel WILL NOT fit.
Also, the DSG shift knob from a GTI/R32 will not fit any other Mk5. The shifter mechanism is different and would need to be swapped to allow the knob to be changed to that style.
Previously:
Old 01-14-2010, 03:25 AM
Default I'd like to change my Beetles wheel
I may start shopping for used replacement. I think my '02 Beetle's steering wheel is the least comfortable wheel I've handled. I like a simpler round or oval cross section, not the complex one of the stock NB, which only fits my grip when I steer with one hand, palm up and elbow on the armrest. The stock wheel is too big, too, making the steering too light and too slow. Does anyone seriously have trouble turning a steering wheel these days?
Old 01-14-2010, 03:43 PM
We do have the R32 steering wheel available, but as mentioned above, they are fairly expensive.
Volkswagen Golf IV 1.8T > Interior > Steering Wheels
They do not include an airbag, but any airbag from a Mk4 3 spoke steering wheel will work. I had one of these in my Mk4 years ago and can say it is a very nice upgrade that you'll enjoy every time you are behind the wheel.
Old 01-17-2010, 03:08 AM
yoyorob's Avatar
South Beach, FL,
Car: 09 Vert
Default Hey now...
my next mod...
Old 01-17-2010, 02:16 PM
Hollywood's Avatar
RUF BUG STAGE II
Trumbull, CT, USA
Car: 2002 NB Turbo S "Ruf Bug"
Just received a new wheel for the RUF BUG:
I have a MINT CONDITION TURBO S steering wheel complete w/Airbag for sale. I know it's not an R32, but thought I'd post up here as many people have inquired about these as well. You can find it here:
VWvortex Forums: Misc. Turbo S / 1.8T Parts For Sale
This Ain't Yer Daddy's Beetle
www.rufbug.com
The RUF BUG
http://www.newbeetle.org/forums/phot...-stage-ii.html
Old 01-17-2010, 02:43 PM
yoyorob's Avatar
South Beach, FL,
Car: 09 Vert
come on man, put it on already!!!! wear a coat if the garage is cold.....
Old 01-17-2010, 02:50 PM
Hollywood's Avatar
RUF BUG STAGE II
Trumbull, CT, USA
Easy for you to say, sittin' in South Beach!
Actually, I'm rather enjoying having it in my office, so I can play with it and hold it during the day.
My Custom Steering wheel :-D xXRockyHorrorsXx Styling Modifications 22 04-30-2006 06:47 PM
How to remove Steering wheel VW2.0Driver Questions, Issues, Concerns, or Problems with the New Beetle 9 11-04-2005 06:09 PM
Steering wheel logo Turboboy Styling Modifications 1 11-02-2005 04:14 AM
Steering wheel options?? Photo Styling Modifications 3 09-28-2005 05:01 PM
