Where to hang my new XM sat radio - NewBeetle.org Forums
Old 05-26-2006, 01:31 PM
Kholw's Avatar
Sunnyvale, , CA,
Car: 1998 NB TDI
Default Where to hang my new XM sat radio
I got a Rodey2 XM sat radio cheap $12.95 they are closing them out. Now where do you hang yours ? Any home made mounts?? Let me know!
Old 05-26-2006, 01:33 PM
FineExampl's Avatar
Poopship Destroyer
Edison, Dirty Jersey, USA
Check my pic thread. Than go to www.myradiostore.com and order one for yourself.
LOOK AT MY Bug!!!!
Old 05-26-2006, 05:57 PM
JohnnyJet's Avatar
final edition?
Long Island, NY, USA
Car: Final edition Coupe
i have Sirius and i mounted it as follows. I mounted the antenna on the roof next to the am/fm antenna. Ran the antenna wire under the hatch back weatherstrip to the point where the grey panel meet the black in my car. Then I wen along the passenger side of the seat pushing wire behind cushions. from there it goes under the floor mat and then into the seam between the console and the floor. I velcroed the unit to the console. Power wire is right there. I can send or post pics if you need them. I like the sat radio so much i only have one preset set in my Bug on Fm and two on am. Feel free to contact me if ya need any help. Oh and I also glued some felt on the bottom of the antenna so it doesnt scratch the paint.
Old 05-26-2006, 06:09 PM
FineExampl's Avatar
Poopship Destroyer
I mounted my antenna right behind the regular antenna....into the trunk....tucked into the mouldingalong the roof all the way to the dash.....trucked into the sides of the dash and the windshield ...into the unit....tucked the excess under the dash panel closest to the windshield. Not the most perfect method, but it's hidden rather nicely for my purposes. Plus it's removable if need be.
Old 05-27-2006, 06:51 PM
JohnnyJet's Avatar
final edition?
nice-- sounds like you mounted your hign, me low. All works. Cant see payin for a pro install.
Old 05-27-2006, 07:19 PM
Oyveychris's Avatar
I love my family!
Knoxville, TN, USA
Here's my mount, although I need to put a spacer behind it to bring it forward a bit.
(\__/)
(")_(")
Me: www.myspace.com/beetlenut
Old 05-27-2006, 08:35 PM
Kholw's Avatar
Sunnyvale, , CA,
Car: 1998 NB TDI
Default Thanks Oyveychris
I was thinking about putting in the same spot but it seams a bit to far away.
I place the ant. behind the ve ant. and tucked the wire as I came forward!
Keep them comming and if anybody made a homemade mount lets see it!
Khol
Old 05-28-2006, 08:17 PM
mojo_trixie's Avatar
Fayetteville, AR, USA
Car: 2000 Reflex Yellow GLX 1.8T
Here is mine mounted...
Trixie
Places to hang with your car on LI WNAB911 Event Planning Archive 1 05-08-2006 08:09 PM
TVA Moving Sale Sat May 13th bugnbox Event Planning Archive 8 04-29-2006 05:16 AM
My local hang out hit by bus! bugsy98nb Miscellaneous Hoo-Ha Archive 5 12-03-2005 03:30 AM
where do you hang out... Tommy Miscellaneous Hoo-Ha Archive 19 11-09-2005 11:45 PM
move my kid day ,,sat the 12th Bugman Event Planning Archive 4 11-09-2005 03:21 PM
