Issues in my '99.. - NewBeetle.org Forums
Old 10-25-2006, 03:18 PM
pinktimbs's Avatar
Baby, I'm bad news.
Fredericksburg, VA, USA
Car: 1999 Silver NB
Unhappy Issues in my '99..
Hi there, everyone.
Basically, I'm the 2nd owner of a '99 2.0 liter. I bought her last December and things were fine until about January when I started noticing that she would do the "idle and then slam into gear" thing when I first started her up. I had the oil changed and had new filters put in in February, which seemed to solve the problem at the time. The slamming stopped for a little bit. It returned and in early June, I had the transmission fluid changed. Sparkle has over 90k miles on her, so I knew it was probably time anyway. The slamming stopped again, only to recur again in late September.
Since I'm used to it, I can kind of anticipate it and I ease into it so that it doesn't slam nearly as hard.. but it's still a pain in the youknowwhat. (Plus, it can only get worse. Heh.)
Also, there is a check light on in my car currently. It's not the check engine light, but the one for electronical stuff - I can't remember the name of it at the moment, but when I searched the forum for info on it it came back that people usually run the codes on their car when this light comes on to diagnose a problem. The light stayed for a day or two, then disappeared for a week or so. It came back on the other day and has stayed solid (which is good 'cause I read that blinking means it's possibly something with the catalytic converters).
The car also idles a little when I'm at a light or waiting. It's like it jolts itself a little bit, not enough to be noticable to other drivers, but just enough that I can feel it.
I'm assuming I need a new transmission, huh?
More panic than intent; more luck than good judgment.
David Gray | "Destroyer"
This is Shannon. | This is Sparkle. | This is my (new) MySpace.
Old 05-18-2007, 03:23 PM
just another peon...
vicksburg, MS,
Car: 98 Red "Sport" - 2.0l Auto
You ever find out what was causing this?
"i beat the internet, the end guy is hard."
Speedometer Issues yodleboy Questions, Issues, Concerns, or Problems with the New Beetle 2 09-03-2006 06:52 PM
1.8t issues exzotikbeetle 1.8 Liter Turbo 3 06-22-2006 02:19 AM
Tint Issues Phxcoop Questions, Issues, Concerns, or Problems with the New Beetle 15 04-01-2006 05:54 PM
Headlight issues newbeetleman 1.9 Liter TDI 9 01-31-2006 05:46 PM
Leatherette issues Deserion New Beetle Detailing/Cleaning 4 01-04-2006 05:27 PM
