Hard to get into 5th gear, 30 miles later, no gears! - NewBeetle.org Forums
Old 05-06-2007, 02:58 AM
VW Kung Fu Master
Salt Lake City, UT, USA
Car: '00 Batik Blue 1.8t GLX
Question Hard to get into 5th gear, 30 miles later, no gears!
I was towing a light load this morning to the dump. Probably no more than 300 pounds total including trailer weight. I noticed that shifting from 4th to 5th was difficult- like I couldn't get into 5th. I downshifted to 3rd, then tried down to 4th then up to 5th and it worked eventually. THis happened a couple times on the way to the dump (45mph max).
Later, I towed approximately 1000 pounds over 20+ miles with no issues. I unhitched, then drove (trailer-less) approximately 12 freeway miles, then maybe 3 miles stop-go city driving. I was just loafing along at about 40mph in 5th gear (it happened while in gear for a minute or more) when all of a sudden the car started making grinding sound and the engine apparently was no longer putting power to the wheels. I tried another gear but immediately heard the same grinding sound. 3rd netted the same result. I used my remaining speed to round a corner and park on a quiet residential street.
All gears are non-functional. I can start the car while in neutral and depressing the clutch. Changing gears (while clutch is depressed) nets some short grinding noises that are not normal. Any act of trying to disengage the clutch while in any gear results in clear sounding gear grinding. No gears actually engage and a lot of gear grinding racket ensues.
I've got about 82k miles on it so far and haven't had any previous transmission/driveline problems before. Does this sound like a transmission mount, engine mount, or some sort of shift linkage problem, and not a transmission malfunction? I'm weighing the options since I've got SUnday to wait it out before deciding where to have it towed (dealer for possible warranty service and week+ wait, VW repair shop for quick/cheap repair but bad part of town...etc.).
Whaddya think?
-ben
'69 beetle
'00 newbie turbonium
Old 05-06-2007, 03:03 AM
OH, USA
Car: 03 GTI
I'm thinking you might get lucky and it'll just be a linkage problem, but who knows? Can you have someone move the shifter while you look down at the top of the tranny and see if anything is disconnected or very sloppily functioning?
Old 05-06-2007, 05:07 AM
ristinkay's Avatar
ristinkay
Cranbrook, BC, Canada
Car: New Beetle 2001 1.9 TDI Silver Arrow Mettalic
I did that to my golf once and it was a cv joint if I recall!!
Diesel Fumes make Me horny
Old 05-06-2007, 08:28 AM
SilverSportNOLA's Avatar
Faster Than Katrina
Formerly New Orleans, LA, USA
Car: 01 Sport
I doubt a CV will make that noise when shifting.
Can you shift the car into each gear when the engine is not running?
I have had this happen once on another car ... and for a GLX you are at the right mileage for a new clutch if you still have the OEM one in there. Most of us have clutch slippage ... sounds like yours is either pressureplate or throughout bearing failure. Tell us what the clutch pedal feels like also.
Old 05-06-2007, 11:34 AM
Old Skool .org Member
Warner Robins, GA, USA
Car: '01 Yellow GLX / '02 Benz SLK32 AMG
With the car off, push on the clutch and go through the gears. If it feels like they all go in to place, jack each wheel and have soomeone twist it while you look at the inner CV boot. My guess it you cracked the tripod. Broken inner CV Joint will not allow you to put it in gear with the engine running (grinds)... been there - done that!
Also, I had a tough time getting reman's from ANY local places (NAPA, Autozone, O'Reillys, Advanced...) Ended up getting some beefed up billet ones from here: http://www.driveshaftshop.com/item135665.ctlg
* That cost ($300) is for the set. If you call them, you can order just one, I believe.
Old 05-06-2007, 09:35 PM
digitalputty's Avatar
Where is home ....
Lone Tree, Greeley, USA
Car: 2003.5 GLS BLCC (Zoomer)
Ouch!
Can you really tow that much in a bug safely?
J'veux pas mourir tout seule.
Old 05-06-2007, 09:50 PM
VW Kung Fu Master
Yes, 1000 pounds is within the allowable towing capacity of the car. So I've read at least.
I just went to check again today (sunday, no shops are open) and learned some new stuff. I'm unable to let out the clutch at all without hearing grinding. No neutral, no 1-5 or R.
-ben
'69 beetle
Old 05-07-2007, 12:54 AM
mgwerks's Avatar
Cherchez la coeur...
Bandera, Republic of Texas,
Car: Oso - a black 99 GLS TDI
Originally Posted by digitalputty
Ouch!
We've pulled over 2000 lbs with Oso, but then again, he's a TDI!
Your fog lights are on,
It isn't foggy today -
You are a doofus.
Old 05-13-2007, 05:19 AM
So how did it go?
Old 05-17-2007, 02:17 PM
VW Kung Fu Master
The dealer quoted around $1000 for a clutch replacement using remanufactured parts. They wanted $1700 for replacement parts using new VW stuff.
I had it re-towed back to my regular shop and they did it for around $950 with new OEM stuff.
-ben
'69 beetle
Old 05-18-2007, 12:25 AM
Faster Than Katrina
Car: 01 Sport
Too Bad you went with OEM, it doesn't last as long as most Stage 1 Kits and costs more.
Old 05-23-2007, 04:01 AM
VW Kung Fu Master
I'm fine with the OEM. I drive like a senior citizen now and needed the car anyway (no time to wait for many days for parts).
-ben
'69 beetle
Old 05-23-2007, 07:51 AM
ney-ho-ma? (how are you?)
Colorado Springs, CO, USA
Car: 03 convertable
Talking
Originally Posted by nebben
>>>I drive like a senior citizen <<<
-ben
'69 beetle
OUCH!! Youngster!!! I AM a senior citizen and drive my wife's bug like a joungster, I have you know. Sorry 8*)
BTW, My son Sam works at the Goodyear tyre store in Sandy, UT. He's got the JETTA bug and seems to know quite a bit about the A4 based VW's.
Rocky Mountain Hi_gh
Only 2 gears work on 5 speed manual Help! hnbeetle Transmission Talk 2 10-22-2006 08:59 PM
Hard to get in to 1st gear mike 51 Transmission Talk 5 08-31-2006 07:53 PM
5 speed Transmission wont go into any gears Spyda-mike Transmission Talk 1 08-09-2006 11:19 PM
5 speed 1.8t wont go in to any gears while car is on. Spyda-mike 1.8 Liter Turbo 3 08-09-2006 09:13 PM
Problem with shifting gears Mazzzja 2.0 Liter Gas 11 03-11-2006 09:13 PM
