2.0 Gas New Beetle won't shift to 4th - NewBeetle.org Forums
Old 08-12-2007, 04:16 PM
Default 2.0 Gas New Beetle won't shift to 4th
Hi,
We recently moved from the USA to Europe and took our automatic 2.0 beetle with us. It sat idle from March this year until a few days ago. We have noticed in the course of a few drives that the car is not shifting to 4th. It will shift from 1-2-3 but remains in 3rd even at high speeds.
Is there anything I can do or check before taking the car to a mechanic?
Old 08-12-2007, 04:51 PM
vdubbugman53's Avatar
Arvada, CO, USA
see if you can get a VAG on it.
Old 08-15-2007, 05:11 AM
basskleff's Avatar
change the transmission fluid and filter.
See if it makes a difference
How to install a shift knob/shift boot denisse 2.0 Liter Gas 1 03-16-2007 02:17 PM
Can't Fill Beetle With Gas!!! bobaloo71 Questions, Issues, Concerns, or Problems with the New Beetle 16 02-08-2007 02:40 AM
99 coil went out, now auto trans wont shift into 4th abrison Transmission Talk 0 01-06-2007 05:10 AM
Beetle Shift Timing any help adam454c Transmission Talk 2 12-11-2006 02:41 AM
diesel or gas beetle? robpad 1.9 Liter TDI 10 12-02-2006 08:25 PM
