Starter has hard time turning engine.... - NewBeetle.org Forums
Old 10-15-2007, 04:40 PM
Default Starter has hard time turning engine....
I got ran off the street and ended up hitting the curb and going over it. Damage looks to be only to the body and wheels/tire, but later after I got it home it was more. I put a hole in the oil pan near the oil pump sprocket; the tie rod is bent; looks like the strut is damaged too, tire rubs against it; tore up the outer cv joint boot; don't know about drive axle, but from the force of impact, could it have damaged my torque converter.
The reason I ask is because the starter has a really hard time turning the engine over; smells like it getting hot. It's also hard to turn the engine over by hand in a few spots.
New battery; new oil pan. When I had the oil pan off, the oil pump chain and sprocket looked ok.
I'm at a point where I don't know if its worth fixing. Oh by the way, the RR tire and wheel was damaged beyond repair; the RF wheel is also damaged, the tire looks ok. I have pics but they are too large to post, I'll have to resize.
HELP? (on resize too)
Dead Spot? Hard Time Accelerating drrroplikebeats Transmission Talk 0 08-07-2007 09:03 PM
What's that squeak from my engine when I shift hard? spinjector 1.8 Liter Turbo 4 07-30-2007 05:33 AM
Engine turning over followed by a brief screeching noise - What is that? ptmlinh 2.0 Liter Gas 5 11-04-2006 08:44 AM
Check engine light and Day time running lights b6057 2.0 Liter Gas 3 10-23-2006 05:28 PM
Having a hard time editing my posts... AmyJane Suggestion Box 10 10-14-2005 07:48 PM
