How do you check the automatic transmission fluid level?? - NewBeetle.org Forums
Go Back   NewBeetle.org Home > NewBeetle.org Forums > 1998-2011 New Beetle > Transmission Talk
Old 05-15-2008, 08:13 PM
Question How do you check the automatic transmission fluid level??
Hello all,
Newbie owner here with a recently acquired '99 Beetle. Looking on this forum, I see a lot of discussion on how to change the trans fluid on an automatic, but how do you simply check the fluid level? I spent quite awhile looking for a dipstick on my car.......only to finally realize that there wasn't one! (I didn't receive an owner's manual with my car.)
I found something online that says you have to warm the trans up, and then remove a plug and see if fluid comes out?? It also said that I need a VW scan tool as well to monitor the temp? Did VW really make it this hard just to simply check the trans fluid??
Old 05-16-2008, 02:06 AM
OH, USA
Car: 03 GTI
Originally Posted by bxtech
...I found something online that says you have to warm the trans up, and then remove a plug and see if fluid comes out?? It also said that I need a VW scan tool as well to monitor the temp? Did VW really make it this hard just to simply check the trans fluid??
Yes, they did make it that hard. Here is a How-to thread for changing and it explains the process for checking:
http://www.newbeetle.org/forums/showthread.php?t=1036
Old 05-22-2008, 08:13 PM
Boy.......what a hassle!! Thanks for the link though. It is very helpful!
Old 03-17-2010, 12:42 PM
Quite a difficult one... I am also searching the same ... Anyone have any idea...?
STEVE
Old 03-17-2010, 01:17 PM
70autostick's Avatar
VW Junky
Car: 1999 GLS 2.sl0w
To make a long story short...
-Transmission temp @ 35-40 degrees Celsius
-Remove drain plug
-allow it to drain to a trickle...
-Nothing coming out? Add fluid,allow to drain out to a trickle.
Old 03-17-2010, 06:30 PM
DZLBUG's Avatar
Probably MIA
Blaine, MN, USA
-Remove drain plug
True dat. An important note however is to do this with the engine running. If you do this with the engine off your level will be too low as the torque converter will only be half full.
2000 New Beetle GLS TDI
Old 03-17-2010, 08:39 PM
VW Junky
Arg!I had forgotten about this,yes,very important....,and if you need to add fluid,Pentosin is the way to go
Old 05-27-2010, 02:23 PM
I'm getting ready to change the transmission filter and oil on my daughters beetle,my question is where can I buy Pentosin synthetic oil at?
Old 05-28-2010, 03:41 PM
Any one out there to help me out?
Old 06-05-2010, 11:52 PM
Thumbs up
try this website.
Auto Parts & Auto Accessories - Over 6 Million Auto Parts, Aftermarket Parts, Truck Accessories & Car Accessories
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
automatic transmission.. ayoari The New Beetle Experience 3 05-28-2007 02:12 AM
ATF level check w/out VAG-COM? iFixBethsBug Transmission Talk 6 08-03-2006 03:00 AM
Transmission Fluid/Oil - how much I should put in? marcellus 1.8 Liter Turbo 1 05-06-2006 05:55 PM
how do you check tranny fluid level on 5 speed? bigblock2336 Transmission Talk 2 02-06-2006 04:43 PM
Transmission Fluid BLAUPUNKT Technical Modifications 2 02-04-2006 06:16 AM
