Is there a clutch adjustment? - NewBeetle.org Forums
Go Back   NewBeetle.org Home > NewBeetle.org Forums > 1998-2011 New Beetle > Transmission Talk
Old 10-25-2008, 12:38 AM
KansasDiesel's Avatar
Just Bugged
KS, USA
Car: 2001 and 2002 New Beetle GSL TDI
Default Is there a clutch adjustment?
I know these are hydralic clutches. But, I just got our 2nd NB TDI and I barely lift my foot off the floor and it's engaged. Much different then my wifes Beetle. I search the Manual and not sure why I can't find anything on any adjustment for that. Can anyone point me in the right direction.
My car "Gus" Gray 2002 NB GSL TDI has everything even leather and sunroof
MY wifes car "Daisy" a Yellow 2001 NB GSL TDI everything but leather and sunroof.best mpg 53 and 805 miles in one tank
Truck Black Ford F350 Powerstroke Diesel (of course),CC,dully, 350hp+ running on WVO!
Old 11-02-2008, 01:25 AM
Champlin, MN, USA
Car: 2001 GLX
I don't think there is any adjustment, if there is it would be at the slave cylinder, but I'm 99% sure there isn't, my clutch engages quite low to the floor, and I think most do, you might try bleeding your clutch? Its pretty easy, the fluid is in the same reservoir as the brake fluid (DOT4) and you'll need to remove the airbox to get to the bleed screw, after that, just bleed it like you would your brakes!
Good luck,
Matt
2000 New Beetle GLX - 1.8T (APH) - A/T - Black
2001 New Beetle GLX - 1.8T (AWV) - 5 speed - Silver
Old 11-02-2008, 11:39 AM
NBTurboFreak's Avatar
20V GTRS
Car: 2001 Sliver Arrow GLX
There is not an adjustment for the clutch. I have a stage II clutch kit and the pedal feels the same as stock other than mine engages a hair sooner due the the stronger pressure plate.
As pfeifervw stated you may try bleeding the slave cylinder and see if it helps.
Piczo Pics -- WoW
2012 Tiguan S 5-speed candy white (new daily)
2013 Beetle Turbo DSG (sun and sound) reef blue
Old 11-02-2008, 11:13 PM
Just Bugged
KS, USA
I was at a TDI GTG yesterday, and talked to a couple people there, they said the same almost right off the floor it's engaged. I guess my wifes beetle is the oddball.
I will go ahead and bleed the system and see if it gets better, I also get a little shutter when I take off from first gear as well. If that duel mass pressure plate is cracked how will the clutch act?? Not that I'm looking for an excuse to install the VR6 clutch.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
Head Light Adjustment Lew 1.9 Liter TDI 4 11-27-2008 07:29 PM
clutch adjustment?? woody95124 Questions, Issues, Concerns, or Problems with the New Beetle 2 08-28-2007 11:38 PM
Headlight Adjustment/ Aim Switch.. ???? amari 2.0 Liter Gas 4 08-07-2007 06:45 PM
Camber Adjustment?? is it possible? Silverbullet007 Questions, Issues, Concerns, or Problems with the New Beetle 7 06-24-2007 06:31 PM
