Speed Sensors - NewBeetle.org Forums
Old 04-06-2009, 11:15 PM
Default Speed Sensors
My Car was in limp mode (stuck in 3rd gear) I took it to the dealer to get the transmission reprogrammed. Now it shifts fine, but I was told that I need to replace 3 speed sensors. I have only managed to find one, that is on the transmission, does anyone know where the other two are located, and is this something a normal mechanic would do. I understand that the car needs to be reprogrammed once the sensors are changed, The dealer wanted $900 to replace all three and to reprogram the trans.
Old 04-08-2009, 04:25 AM
I had the same question and looked and found them with Google.
(I have the manual ordered)
Look at the inside of the wheels,mounted inward of the break disks.
DP
Tags
limp mode , speed sensor , transmission
5 speed to 6 speed manual swap the outcome FallinApartBoy Transmission Talk 23 03-20-2012 02:39 AM
Small noise at speed up / speed drop gowen Questions, Issues, Concerns, or Problems with the New Beetle 5 10-07-2008 08:04 PM
where can i buy vehicle speed sensors garay77n84 Transmission Talk 3 04-16-2008 12:40 AM
Fan Sensors ? vdubs 2.0 Liter Gas 2 08-01-2007 02:19 PM
o2 sensors. puertorico 2.0 Liter Gas 2 05-05-2007 05:46 AM
