Trouble Shifting into 5th Gear! Help - NewBeetle.org Forums
Old 06-09-2009, 05:32 PM
beetlejuice27's Avatar
2Gud4U
Franklin park, IL, IL, USA
Car: I drive a Black 2000 1.8 L turbo Volkswagen Beetle
Unhappy Trouble Shifting into 5th Gear! Help
Hello everyone, i need help figuring out what to do in order to get my 5th gear back to normal. All of my other gears are good when i shift besides 5th. When i attempt to shift into 5th it goes into place but it does not engage.
I tried messing around with shifting rods right below the intake, (air cleaner) but that just messes up all the rest of the gears when shifting. help please!!
Old 06-09-2009, 06:01 PM
noR's Avatar
Administrator
Jackson, MS, USA
Hrm, I wish the problem was 1st instead of 5th.
I'd like to see you try to to put it in 5th gear using the shift-linkage weight on top of the transmission. Get it into position and see if it "works". But to test that, well; it's REALLY HARD to start moving in 5th gear from a stop. ... so I'm not sure what to do next.
I'm inclined to think the problem is the side-to-side linkage only. And maybe it just needs adjustment. It shouldn't mess up all the other gears, only R, 1, and 2 if any.
The problem MAY be internal if you can't fix it w/the adjustment cables.
Or maybe it's just that linkage connection itself that is the problem....
noR | me | Phrog
PHROG
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
Follow the proper adjustment procedure found near the bottom of this link:
Sigma 5 Install Manual
How is your fluid level? Has it been changed ever? 5th gear runs outside of the deeper part of the case and is the first to be damaged if fluid is allowed to drop below the proper level.
2000 New Beetle GLS TDI
Old 06-13-2009, 02:48 PM
2Gud4U
Default out of reach
well before i do any disassembling,it feels like its not reaching. when i shift to 5th, its like too short to engage. it stays in neutral. any suggestions?
Old 06-13-2009, 03:01 PM
DZLBUG's Avatar
I Am Breitbart
Linkage adjustment doesn't really require disassembly, go through the process that I linked you to.
Inspect the linkages for any excessive play due to worn/broken parts. Particularly on the side-to-side linkage, sounds like the cable might be loosing some of its "reach" to get into 5th. Have a helper shift through the gears as you watch the linkages.
And if you're over 100k miles, change your fluid!
Manual transmission fluid change how-to with pics - TDIClub Forums
2 liters is the dry fill capacity, so a little less than 2 will fill it up. Some people like Redline MTL, but I would probably stick with the VW G52 or new G70.
Drain plug is on the bottom, fill plug is on the front side. 17mm allen. 18 ft-lbs on the plugs, aka "guttentight" with a 3/8 ratchet.
Old 06-17-2009, 05:49 PM
2Gud4U
Default 100k
I just hit 100k miles....
thanks for the link DZLBUG!
not shifting to 2nd gear help!! chunkybabygurl 1.8 Liter Turbo 3 08-25-2009 10:24 PM
Delay in Gear Shifting? kate_the_valkyrie 1.8 Liter Turbo 5 03-12-2008 10:57 PM
Shifting Problem/Limp Gear bchasse Transmission Talk 1 07-14-2007 08:35 PM
auto tranny having trouble shifting co-ed_bug Transmission Talk 4 12-09-2006 06:10 PM
Dealer diagnosis for trouble shifting $$$ my99vdub 2.0 Liter Gas 0 05-02-2006 01:52 AM
