1.8L turbo GL auto trans. - NewBeetle.org Forums
Old 12-08-2009, 02:29 PM
Terryville, CT, USA
Car: 2003 1.8 L turbo GL
Default 1.8L turbo GL auto trans.
My 2003 Turbo GL has 103,000 miles on it and is exhibiting some potential transmission problems. It takes several seconds, especially when shifting to reverse, for the transmission to engage. I would like to keep this car for another 100,000 miles. What is involved in a full auto-trans service? I keep hearing it is a "sealed unit". However there is a drain plug, which means to me that the fluid can be replaced. Is there anything else (filter, gasket etc.) in a complete transmission service? Would just a fluid change cure the "delayed trans engagement" syndrome?
If this has been covered in another thread, I apologize. I have not been able to find it.
Thanks so much.
Mike
Old 12-08-2009, 02:33 PM
You can do a fluid flush, but its not uncommon for the VW auto transmissions to die around 100k.
I would do a flush and see if it helps. If not, you could be looking at a new trans. Pretty common to do a 5-speed swap, as its cheaper than an auto and lasts far longer and is easier to maintain.
Old 12-09-2009, 01:02 AM
The Cheat's Avatar
overwhelmed/underpaid
New Britain, CT, USA
turbo gl?
automatic?
in ct?
rock and roll!
fwiw, i'm fairly local, wouldn't mind tackling a fluid change on it for ya.
Old 12-09-2009, 01:47 AM
70autostick's Avatar
VW Junky
Car: 1999 GLS 2.sl0w
I'd take up on cheat's offer Mike,he's got the skeelz...I think it may be time for a flush n' fill + filter...
A sloppy auto at 100k isn't unheard of,if it doesn't come around,a 5speed swap is the way to go,bud
Old 12-09-2009, 02:09 PM
Terryville, CT, USA
Thanks for the replies. I sent a PM to The Cheat. We are practically neighbors. I am definitely not averse to swapping out for a 5 speed if it comes down to that.
WTB: BAD Auto TDi trans... beetlecupkid Parts and Accessories 7 08-03-2008 09:00 PM
Will a 2003 New Beetle 2.0l auto trans work in a 1998 new beetle 2.0l auto? SLC Dubster Transmission Talk 4 10-01-2007 03:17 AM
auto trans. robpad Questions, Issues, Concerns, or Problems with the New Beetle 1 10-23-2006 06:39 PM
1.8 turbo auto trans hawky 1.8 Liter Turbo 4 02-06-2006 04:36 AM
