1st gear griding. - NewBeetle.org Forums
Old 04-01-2010, 02:09 AM
Default 1st gear griding.
Hi everyone, this is my first post here. I just got a 1999 beetle 5 speed gls but sometimes i have a problem with 1st gear. Sometimes when i shift in first gear i feel a griding noise and some other times it wont shift easy in first gear. The other 2/3/4/5 and reverse are just fine. Any suggestion it will be highly appreciated.
Regards
Old 04-01-2010, 11:55 AM
akasha1963's Avatar
Kaylee Bug
Nashville, TN, USA
Car: 2001 Silver Arrow GLS 2.0
Are you making sure the clutch is to the floor when going into 1st?
Old 04-01-2010, 01:19 PM
Yes the clutch is to the floor.
Old 04-01-2010, 02:01 PM
I'd start with adjusting the shift linkage. Mine was getting notchy and first was being a pain. Then a plastic piece of my shift linkage broke. I would definitely take a look at the linkage first.
My fiance had a '95 Passat that you had to throw into second in order to get it into first. His shift linkage went and after he fixed it and got it adjusted, it shifted like butter. All his other gears were fine before that too.
Tags
griding
Hard shifting in to 1st gear and second mike 51 Transmission Talk 0 08-13-2009 09:29 PM
Hard to shift into 1st gear rooney77 1.9 Liter TDI 9 03-04-2009 10:11 AM
Hesitation in 1st Gear MandieGirl Transmission Talk 3 11-09-2006 05:14 AM
Hard to get in to 1st gear mike 51 Transmission Talk 5 08-31-2006 07:53 PM
Trouble getting into 1st gear iScott 2.0 Liter Gas 21 07-14-2006 07:33 AM
