When I have the transmission in Tiptronic mode sometimes when I come to a stop it will shift back into 1st gear and sometimes it stops at 2nd gear. When I shift the first time after starting again I end up shifting into 3rd when I think I'm going into 2nd. Is this normal behavior in Tiptronic mode?
Donate the time your computer is turned on, but is idle, to projects that benefit humanity. Join the World Community Grid. http://www.worldcommunitygrid.org |
Thanks for the reply. Here's the scenario:
Driving along shifting up before getting to redline. Come to a red light and stop (letting transmission down shift by itself). Signal changes green and I accelerate. Car starts off in 2nd gear. Sometimes it does this and other times it starts in 1st gear. Doesn't seem to be any consistency as to whether it starts in 1st or 2nd. |
Yes I would say it's normal. Mine does that too. However, I believe there is a time window that if you remain completely stopped - and I mean dead stopped no rolling - it will downshift to 1 after the time windows passes. How long is this window? I don't know. I never timed it. You can always override however - either downshifting to 1 or upshifting to 2 as the case may be. There may also be some smart logic in the trans controller too affecting the shifts. Honda has something called "grade logic" in their automatics which can sense when you are going uphill or downhill. Maybe there's some similar logic in these tiptronics influencing the shift points.
| Tiptronic Issue | oceanjoe89 | Transmission Talk | 21 | 08-08-2011 11:23 PM |
| Tiptronic Switch | oceanjoe89 | Transmission Talk | 10 | 08-15-2010 07:11 PM |
| TipTronic not working.. | banans | Transmission Talk | 5 | 09-14-2008 03:00 AM |
| TipTronic question?? | redoodlebug | Transmission Talk | 0 | 05-23-2008 12:14 PM |
| Tiptronic question | kazze | Transmission Talk | 4 | 03-30-2008 06:00 PM |
