I'd hate to see you get rid of your beetle. But if you can't afford to keep her up financially (Swap for a manual trans), or afford to keep her around as a project car, it might be best to sell.
All the best with your decision.
Dang,I'm sorry for your troubles,@ only 72k too
![]() I too had the same troubles going up or even downhill,and letting off the gas right before it changes gears caused a rough shift. If you've already cleaned out the fluid+filter,try disabling the "Fuzzy Logic" with VAG software,may not fix her completely,but I guarantee results. It disables the "learning" process,it makes the gear changes more solid and less awkward. Before you rid yourself of that beetle,try a different setting,sport mode worked great for me,@ 115k,its shifting has actually gotten better the past 5k C0,Automatic Transmission (01M) Coding C1,000?x - DSP Mode (Dynamic Shift Points) C2,0 - DSP active C3,1 - DSP inactive C4, C5,000x? - Transmission Mode C6,0 - Factory Mode (Adaptive Transmission Mode) C7,1 - Force Economy Mode (lower Shift Points) C8,2 - Force Sport Mode (higher Shift Points) C9, C10,Common Settings: C11,00000 - Factory Mode C12,00011 - Econonmy/Touring Mode C13,00012 - Sport Mode |
Oh,before you change your setting,try the factory 01M reset.
1)Keys in the ON position,warning lamps illuminate,do not start. 2)Depress the accelerator all the way to the floor until it clicks,you'll feel it. 3)With the pedal still depressed past the "click",hold it there for 10 seconds,its actually 5,but to be safe... 4)From that point,continue to start the car and take it easy,no drag racing for the next 100 miles ![]() You should notice a differ within 5 miles. |
you could also try to flush the fuild again.
the problem with auto tranny fluid changes is that the new fluid knocks loose alot of sludge so the symtoms can return quickly.
sold the beetle, don't use the site anymore |
I'd say set the tranny to "economy" mode. Shifts sooner and better fuel economy. If it wasn't for "eco" mode on my tranny, my automatic would have died a LOT sooner. Putting a dieing tranny in "sport" mode will only kill it faster. I know someone who can prove this. best to err on the safe side. Take it out of the learning mode and set to "economy" mode. I rode mine for a good...20k-30k like that without any problems until just recently. I now have a 5 spd!
Just because it's done at a Dealer, doesn't mean it's done Right!!! "Probie" 2k12 ToD Checklist Dub Gestapo |
| Say Goodbye. | bugsy98nb | Miscellaneous Hoo-Ha | 27 | 01-31-2009 05:16 PM |
| say goodbye to the Cobra... | loganskinner | Photos: Other Rides | 22 | 10-20-2007 01:23 PM |
| this is goodbye.... : / | v-dubed | Miscellaneous Hoo-Ha Archive | 14 | 11-28-2005 01:45 AM |
