We include (4) in our auto transmission service kits, manual transmissions only require (2).
Volkswagen New Beetle 1.8T > Maintenance > Transmission
http://www.ecstuning.com :: Email: sales@ecstuning.com :: Facebook :: Questions? PM or Email for the quickest response! |
If you have the auto there is separate lube in the diff section from the auto trans. section and it takes less than a quart. You check and fill by removing the speedo drive which is marked like a dipstick. You do not need to "drop the pan" on the auto to do this, however while you're under there go ahead and service the auto portion of the trans. The diff portion and the auto portion require different fluids. Enjoy.
If you happen to have a manual, there is no "pan". You'll need a 17mm hex wrench to drain and fill. |
| Cost of trans fluid change? | flynn18T | Transmission Talk | 23 | 03-21-2012 12:59 AM |
| Trans fluid | saved2 | 2.0 Liter Gas | 2 | 09-25-2009 11:34 PM |
| Trans Fluid Flush | bugasm99 | Technical Modifications | 5 | 01-02-2006 12:23 AM |
| replacing trans fluid | jesse | 1.8 Liter Turbo | 1 | 11-24-2005 10:04 AM |
| When do i change the trans fluid? | jesse | 1.8 Liter Turbo | 7 | 10-03-2005 04:47 AM |
