need help ASAP. five speed won't go into reverse - NewBeetle.org Forums
Old 05-10-2010, 11:48 PM
Default need help ASAP. five speed won't go into reverse
Hi all,
Wife is 300 miles away picking up her new 99 beetle. She said she went to leave and smelled a burning smell and now the car won't go into reverse. Any ideas what it could be? Its a five speed with 90k miles on it. Thanks for the quick replies.
Joe
Old 05-11-2010, 12:06 AM
Will it go into all other gears? Does the shifter feel normal?
At around 90k I lost my shift linkage...all I had was 3rd and 4th.
Old 05-11-2010, 12:40 AM
It sounds like the linkage is broken from what I've read. Is that a standard issue repair? Do most dealers stock the part and if so how long is the job?
Old 05-11-2010, 01:26 AM
If she has a '99, is the same year as mine. On the '98s and '99s there is a plastic piece that brakes. I had my local shop replace mine. It was cheap. I had that done, an oil change, and a fuel filter change for less than $200.
I'm not sure how easy this thing is to repair yourself.
Old 05-11-2010, 01:38 AM
I'm not fixing it. I just hope the dealer has the part and she can head home tomorrow (fingers crossed). Is it a normally stocked item?
Old 05-11-2010, 12:50 PM
Not sure. I had a local shop do mine. They had to order it. I took it to them on a Sunday and it was done on a Wednesday, but I also didn't need it back right away since I had my fiance's car to drive.
Old 05-11-2010, 03:14 PM
All fixed $140. Thanks!
5 speed to 6 speed manual swap the outcome FallinApartBoy Transmission Talk 23 03-20-2012 02:39 AM
02G / GHE 6 Speed TipTronic To 02M 6 Speed Manual Swap! sledge0001 Technical Modifications 31 07-22-2009 04:38 AM
Will a 6 Speed Turbo S Shifter Fit A 5 Speed Boot? sledge0001 Technical Modifications 5 05-01-2009 02:02 PM
Small noise at speed up / speed drop gowen Questions, Issues, Concerns, or Problems with the New Beetle 5 10-07-2008 08:04 PM
