What Scanner do i need to pull trans codes? - NewBeetle.org Forums
Old 05-12-2010, 02:45 AM
Default What Scanner do i need to pull trans codes?
I want to see if my trans is throwing any codes and I also want to change the trans fluid. I understand I need Vag-com or something like it to use with my laptop. Whats the best hardware/software to purchase? I dont need anything over the top, if possible i'd love to be able to pull CEL codes off my 99 bmw too, but not a priority. OH my car is a 03 beetle convertible with the 6spd auto trans
thanks!
Old 05-12-2010, 05:18 AM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
The cheaper KII-USB interface will do what you need:
Ross-Tech: Home
It wont work on your BMW, I'm not sure if there is anything like VCDS out there for BMW's. An OBDII scanner would work for that, but it won't pull transmission codes from your VW and it will not monitor transmission fluid temp as required to get the level correct.
2000 New Beetle GLS TDI
Cheapest OB scanner to clear and check codes zipster 1.8 Liter Turbo 2 10-19-2007 07:14 PM
Cannot pull ODB2 codes??? (Link error) jaxlore Questions, Issues, Concerns, or Problems with the New Beetle 2 10-16-2007 11:53 PM
How do I pull engine fault codes? dsaldiv5 1.8 Liter Turbo 3 08-25-2007 02:33 PM
how to pull CEL codes witout tool? germanturbo 2.0 Liter Gas 3 08-15-2007 01:01 PM
